Prop questions
FormerParatrooper
Prop questions
Post by FormerParatrooper » 01 Jul 2016, 00:08
Prop questions:
The manual calls for a 8x81/2 prop for my 67 Johnson 9.5. What is on it is a 8 1/4 x 8 1/2 . Is this enough difference that when I replace this prop for what the manual calls for that I will see a noticeable difference in performance?
These are pics of my current prop, it is dinged pretty good. I noticed some deformations on the blades themselves, what is the cause of this? What can I do to reduce it from happening? Or is it a badly made prop?
1979 MirroCraft F4604
1967 Johnson MQ13 9.5 Hp
1974 Evinrude 25452M 25 Hp
Life member of the LGOPPs
DaleH
Prop questions
Post by DaleH » 01 Jul 2016, 07:51
I'd use that prop, the 1/4" difference in diameter won't mean anything.
The dings are from someone grounding the OB in shallow water. Don't put a file to it. I smooth out prop dings on aluminum blades using crocus/metal cloth wrapped around a hardwood block.
How to prevent them :?: ? Watch out in shallow water ...
#4 Procraft SV14
FormerParatrooper
Prop questions
Post by FormerParatrooper » 05 Jul 2016, 11:10
Thank you Dale. I will be following your advice. I am purchasing a new prop just to have a back up for anything that may happen on the water. I believe better to be safe and have a spare than to need one and not have it. I have a spare for about everything else that could wrong so a prop would be a good investment.
dootech
Prop questions
Post by dootech » 10 Jul 2016, 21:57
I've used hammer and file to straighten and smooth blades on many a pwc impeller, and those are very sensitive to cavition
