Prop questions
FormerParatrooper
Central Illinois
Prop questions:
The manual calls for a 8x81/2 prop for my 67 Johnson 9.5. What is on it is a 8 1/4 x 8 1/2 . Is this enough difference that when I replace this prop for what the manual calls for that I will see a noticeable difference in performance?
These are pics of my current prop, it is dinged pretty good. I noticed some deformations on the blades themselves, what is the cause of this? What can I do to reduce it from happening? Or is it a badly made prop?
I'd use that prop, the 1/4" difference in diameter won't mean anything.
The dings are from someone grounding the OB in shallow water. Don't put a file to it. I smooth out prop dings on aluminum blades using crocus/metal cloth wrapped around a hardwood block.
How to prevent them :?: ? Watch out in shallow water ...
Thank you Dale. I will be following your advice. I am purchasing a new prop just to have a back up for anything that may happen on the water. I believe better to be safe and have a spare than to need one and not have it. I have a spare for about everything else that could wrong so a prop would be a good investment.
