94' 70hp Evinrude - Siezed then freed
JRyno10
Post by JRyno10 » 01 Jul 2016, 18:45
Long story short my Motor Siezed up and now is relatively free. However the starter can hardly spin the flywheel enough to start it. I want to do a compression test on it but I don't know where to begin. What should the compression be on each cylinder?
lckstckn2smknbrls
Post by lckstckn2smknbrls » 01 Jul 2016, 19:17
Why did it seize? Over heat?
Try pulling the plugs and see if the starter will spin the motor?
Have the starter and battery tested.
Pappy
Post by Pappy » 01 Jul 2016, 19:26
Pull the spark plugs and have a look at them. Probably #2 cylinder. Whatever plug looks different is the culprit cylinder.
Almost all seizures that just involve piston skirt to cylinder wall will free up as the parts cool. This does not mean the engine
is good to go again, not by any means. If you plan on running it with the damage....pour the oil to it!!!
JRyno10
Post by JRyno10 » 02 Jul 2016, 01:37
Yes it Siezed to do an over heat. I guess it will be needing a rebuild?
JRyno10
Post by JRyno10 » 02 Jul 2016, 17:19
Compression test read 65,30,65. Why would all of the numbers be so low?
Pappy
Post by Pappy » 02 Jul 2016, 18:04
JRyno10 wrote:Compression test read 65,30,65. Why would all of the numbers be so low?
Probably the gauge and the fact that you said it is not turning over normally. As I indicated...#2 cylinder is toast.
Pappy
Post by Pappy » 02 Jul 2016, 18:07
There is an updated water pump kit for that engine. Been out for years and years. Chances are you never took advantage of that.
If you do the rebuild make sure you obtain one (not an aftermarket, OEM only) and get the complete kit
not just an impeller. It will have a new thermostat spring, cover, and instructions to re-route the indicator line.
