It is currently 24 Mar 2019, 07:42
VinylImagesInc
 Page 1 of 1 [ 9 posts ]
PostPosted: 11 Aug 2016, 19:25
I just picked up a 1978 sylvan boat and it came with this 1965 9.5 hp motor. Model number 9522c.
I can start it super easy but without the choke it won't run. I will post some pictures, I think it's missing some parts?!
PostPosted: 11 Aug 2016, 19:31
Ok here you can see a shaft sticking out. No clue what it's suppose to connect to.
Here you can see the shaft goes no where.
Runs with the choke pulled 1/2-3/4 out. Not sure where to start on this thing till I know the motor is complete. Thanks for any info
PostPosted: 11 Aug 2016, 20:56
I imagine that was the slow speed adjustment. Trying to find a diagram to figure out what parts I need to order to make it function like it was suppose to again. This motor looks pretty clean other wise, fires up on the 2-3 pull.
PostPosted: 12 Aug 2016, 09:50
Found a diagram. It's the slow speed adjustment. Those parts aren't cheap! Image
Maybe I can adjust it without those parts, be nice to return it to 100% working order tho.
PostPosted: 12 Aug 2016, 09:54
I'd buy things like choke knobs and slow speed knobs and cables off of Ebay rather than new OEM.
http://www.tinboats.net/forum/viewtopic.php?f=21&t=40764
PostPosted: 13 Aug 2016, 10:03
No, your engine is NOT complete!
The shaft you see that goes nowhere is an offset mixture control. It is missing the knob on the outside and the linkage that connects it to the mixture control on the front of the carburetor. Adjust the mixture on the front of the carb for the time being and see if it helps.
PostPosted: 13 Aug 2016, 10:06
Thanks for the reply. I will look up the base adjustment and try it out. Wouldn't happen to know where to initially set it would you?
PostPosted: 13 Aug 2016, 10:22
1 1/2 turns and go in from there.
PostPosted: 12 Sep 2016, 10:48
I basically have that same motor - 66 Johnson 9.5 but mine has the flex cable to adjust the slow speed needle.
Darn fine motors. Be glad to answer any questions I can.
CMOS
1963 Lone Star 14' "Commander" with a 1998 25 HP Mercury
1982 Johnson 15 HP - in pieces, in progress :wink:
Users browsing this forum: Majestic-12 [Bot] and 47 guests
