It is currently 18 Apr 2019, 16:29
 Page 1 of 1 [ 6 posts ]
PostPosted: 29 Aug 2016, 17:17
is there a modern cylinder head temperature gauge that can be installed on older outboards?
PostPosted: 29 Aug 2016, 21:23
http://www.oempartsllc.com/gaugeomcheadtempkit174682includessensorbrktwire2gaugewblackmattefinishbezelnew.aspx
Not a combo with tach.
Power it off a switched hot. Use a cylinder head water jacket bolt to mount the sender. Scrape the paint off the water jacket where the tip of sender seats. Cheap insurance.
17' Pro-Line 115HP DI Johnrude Bay rig
1652 Weld-Craft 50HP Johnrude fish camp rig
17' Grumman canoe 3.3HP Johnrude on side mount creek runner
PostPosted: 30 Aug 2016, 21:35
Just be aware that this is a lousy instrument if you want it to tell you if you just blocked your water intakes. By the time the gauge reacts the engine will be toasted. A water pressure gauge is much faster and will help you keep track of the integrity of the water pump.
PostPosted: 31 Aug 2016, 00:39
Pappy where might one find a nice little water pressure gauge that will work on an omc 15hp?
PostPosted: 31 Aug 2016, 07:57
Here's one that I've used on various OBs through the years. I too prefer using a water pressure gauge vs a temp gauge.
http://www.surplusunlimited.com/mm5/mer ... ode=700-25
Also discipline yourself to look at it everytime you start up and glance at it when changing RPMs (as it will move) and whilst running ... soon it will be 2nd nature to glance at it quickly every so often.
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 31 Aug 2016, 16:13
Where would you get a water jacket on a 15 hp evinrude? I don't see a place on these motors to attach one.
Users browsing this forum: watermaker and 36 guests
BoatCoversDirect
