1975 Johnson 25hp Electric Start
khanderton
Post by khanderton » 02 Sep 2016, 13:50
Just recently, I have been having difficulties starting my motor w/ electric start when the motor is cold. I can pull the rope and it starts. Once started, I can shut it off, and the electric start will work w/o issue. I only seem to have the issue when the motor is cold.
Any thoughts on this issue?
Thanks in advance.
rednecknproud21
Re: 1975 Johnson 25hp Electric Start
Post by rednecknproud21 » 02 Sep 2016, 13:54
Safety neutral switch is probably intermittently working
Sent from my XT1254 using Tapatalk
rednecknproud21
My 1973 did they same thing when I got it changed the switch and now it works like it should
earl60446
Post by earl60446 » 02 Sep 2016, 18:36
Maybe a low battery when cranking the starter. Monitor with voltmeter when trying to start.
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
