It is currently 19 Apr 2019, 06:15
Wired2fish
 Page 1 of 1 [ 9 posts ]
PostPosted: 07 Sep 2016, 16:27
Anyone know where I can get a new seal for the hood on a 1979 Evinrude 6 HP motor? Mine is cracking.
2006 Alumacraft Navigator 165 CS (Crappie Slayer)
2006 Mercury 90 HP Optimax
1979 Evinrude 6 HP Long Shaft Kicker (To be installed)
Minn-Kota Terrova 24V 80# Thrust Trolling Motor w/ I-pilot
2006 Dodge Durango SLT (Bright Blue) 4.7L Next Generation V8
PostPosted: 07 Sep 2016, 17:05
I bought some from NYMarine in Canada.
http://www.nymarine.ca/cowlgaskets.htm
have you tried ebay ??
you have to have a good idea of the profile of your gasket.
Many are similar but some have just enough difference to make it not work.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 07 Sep 2016, 21:41
Sorry if this is a thread jack, but I am thinking of buying one of these OMC 6hp's. Are parts a problem? I know they made a zillion of them.
PostPosted: 07 Sep 2016, 22:09
I've had work done on my motor and my mechanic always seems to have any part he needs. Impellers, water pump, pull rope, etc. But the gasket for a hood I haven't found yet. I've searched eBay already but no luck.
Sincerely,
jbird68
PostPosted: 07 Sep 2016, 22:12
Wow! Not cheap.
Sincerely,
jbird68
PostPosted: 08 Sep 2016, 10:30
LOL - Bird, I was gonna add to my first post "depends on how bad you need it".
yes, they are not cheap - but - they are the only game in town.
I needed 3 for my pre-1960 Johnsons (I have 5 of them) and Pappy needed a couple also.
so we ended up buying 5 or so for a boat load of coins.
When refurbishing an old vintage motor, if you gonna have a nice paint job
you can not have a raggedy cowl gasket ....... thus, forking out the $$$$
If you need parts, Marine Engine has most everything you will ever need.
But, once you cross the age line, a lot of parts are "no longer available".
This is the Cross to Bear if you gonna maintain a nice vintage motor.
http://www.marineengine.com/parts/parts.php
One of the best websites available is http://www.aomci.org - visit the "ask a member"
section if you are having issues with your vintage motors.
Note: IF you decide to purchase the gasket, make tripple sure you cut it
about an inch longer than you need and force the cowl down over it and let it
sit for a few days to acclimate - then, trim and glue it in place with contact cement.
jus my Dos Centavos
PostPosted: 08 Sep 2016, 10:42
For the seal on the hood itself, it almost makes more sense to see if you can find an entire hood in great shape on Ebay or somewhere.
http://www.tinboats.net/forum/viewtopic.php?f=21&t=40764
PostPosted: 08 Sep 2016, 22:07
Have you tried BRP or whoever sells Evinrude motors
and parts? It might still be available.
Steve A W
Professionals build the Titanic.
Amateurs built the Ark!
PostPosted: 09 Sep 2016, 01:33
No hood gaskets or seals as you call them for that old of a motor from brp. You would have to find it at an older dealer sitting in their parts bin for years.
Users browsing this forum: No registered users and 41 guests
SwampRunner
