Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
88 Mariner 9.9 Tiller to control conversion
Riverrabbit
3
Post by Riverrabbit »
I have what I believe is an 88 Merc Mariner 9.9 with a tiller that I want to convert to controls. it's manual start, no trim. so I've been told this is the easiest config since no harness is required. What all would I need? Will any modern mercury control work?
2016 Grizzly 1448 MVX, 95 Johnson 25 2smoker.
Ocean Trident 13 Camo Angler
onthewater102
5
Post by onthewater102 »
Use your S/N and pull up the parts schematics on boats.net and make a list of the motor-side items you'll need. Many of them can be found on Ebay if you know the OEM part number. At that point any mercury throttle/shift controls will work for you. You'll have the pull start still, but that's no biggie speaking from experience I converted my pull start tiller to remote and have no issue turning around to start it (bigger motor same vintage).
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
Riverrabbit
3
thanks for the response, but I'm on to a new plan now. this thread can probably be deleted.
