Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
25 Merc spilt block gasket failure
tomme boy
6
Post by tomme boy »
My 25 Merc has been starting to run really bad at idle. It is also blowing gas out of the side of the block. I was told that this is a common problem with the Merc split case design.
I am going to have to either repair this or get a new motor. Has anyone here done this and how was it? Dealer here want 5 hours min to fix it over winter. He says there is no gasket per say. but just a sealant.
Pappy
Post by Pappy »
Your dealer is correct in that there is no gasket. "Gel Seal" is used to seal the machined surfaces in place of a gasket.
Be prepared to pull the powerhead and remove the front half down to the crank. Flywheel and ignition will have to be removed as well.
turbotodd
Post by turbotodd »
5 hours sounds about right if a dealer's doing it. I remember doing a few of those Pieces of junk back in the day. Merc never admitted that there was a problem with them.
onthewater102
5
Post by onthewater102 »
What year models was this an issue on?
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
turbotodd
Post by turbotodd »
I stepped into the business in '92, and got out of Mercury in 1998 or 9. Don't know what years were affected. Mercosil was also a headache.
