Heavy chevies boat is for real. A bit extreme, but definitely for real. :lol:
What is your transom height Dave? That will determine it. Those lengths aren't there just to fill up lettering space on the box ya know......
Why are you asking about trim tabs? They are tabs that mount to the transom, at the bottom of the hull. They have a little hydraulic cylinder (usually, some have electric solenoids) that will raise and lower them at the press of a button. Since they are hinged at the hull bottom, when lowered, they push down into the water, lifting the boats transom when at speed. Very similar to an airplane's ailerons.
Now, smart tabs are an even better choice for many smaller and medium pleasure boats and fishing boats. They have a gas cylinder, as opposed to hydraulic, so they will self lower. However, when the boat speed picks up a lot, the drag of the water will push them up, as they aren't always needed at high speed. Google them both, and you will get a better mental picture than what I am describing.
