It is currently 26 Mar 2019, 04:55
 Page 1 of 1 [ 6 posts ]
PostPosted: 09 Oct 2016, 12:05
Hi
I finally get my new floor installed into my boat and I thought I would take it out for a test when I noticed that the steering does not work.
Meaning I can't turn the wheel to turn the boat. And this was working a few weeks ago.
I did some troubleshooting.
I unscrewed the steering cable from the motor (picture 111555), now when I turn the steering wheel I can see cable moving in and out of the steering cable sleeve.
Then on the other side of the nut I unhooked the connection (top left) between the motor and the remote steering (111613). The boat tilts left and right fine.
It seems the issue is the piston in the bottom right of 11613 is not moving.
It seems that looking at picture 113504 the remote steering cable enters from the left and is supposed to move the piston on the right in and out which is supposed to move the motor.
Any feedback is appreciated.
Alex
PostPosted: 09 Oct 2016, 14:04
The "Piston" is the end of the steering cable. You will have to get the end of the cable unstuck from the tilt tube.
Try spraying it with PB blaster, WD40 then tapping it with a hammer. Worst case you get a new steering cable.
PostPosted: 10 Oct 2016, 13:09
if the cable is rusted up inside the sheath to the point
that it creates friction and restricts movement,
try this . . . .
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 10 Oct 2016, 16:20
If I am reading you correctly, the steering ram (nut on left-side FACING the motor) is stuck. Meaning the end coming out right side (facing FACING the OB) won't move. It is stuck inside the tilt tube. Some tilt tubes are not stainless steel and they corrode inside.
Get a heat gun to heat & soften old gunk inside that tilt-tube (T-T). If you get it to move, un-do that nut and pull the entire ram of the T-T. Beg/borrow 12-gauge cleaning brush and clean the heck out of the T-T.
You can prevent this by buying a $25 "Steersman" steering ram nut w/ O-Ring that seals and wipes the ram as it is retracted and extended.
See: http://www.steersman.com
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 10 Oct 2016, 16:22
Oh, go buy some "Triple Guard" grease by OMC/Bombardier in a large tub for $10. It is a blue-colored waterproof synthetic marine grease. All OB makers sell it and it all comes out of the same factory, but the US labeled product is much cheaper than that sold by foreign OB makes.
Use this to lube that steering ram inside that tilt-tube.
#4 Procraft SV14
PostPosted: 12 Oct 2016, 16:31
Hi,
thanks for the help. I blasted it with PB a few times and then gave it a sharp tap with a sledge hammer and it came unstuck.
After that I kept blasting it PB and it moves smoothly now.
Thanks
Users browsing this forum: No registered users and 42 guests
