It is currently 19 Apr 2019, 07:07
VinylImagesInc
 Page 1 of 1 [ 8 posts ]
PostPosted: 10 Oct 2016, 22:05
So...I need to rebuild my fuel pump. Took it apart to clean it and lost the first gasket (The one with the large round hole) and now it shoots gas. I have found A LOT of kits that look like they would work but all of the gaskets/diaphragms look different than what is in mine. Can someone point me to one that will work or are the ones I found the right one?
Sierra 18-7823 Fuel Pump Kit
http://www.iboats.com/Sierra-18-7823-Fu ... gQodN14CBw
Sorry for the plug to another web site.
1979 Monark 1443, 1969 Johnson 18Hp Motor
PostPosted: 11 Oct 2016, 09:28
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 11 Oct 2016, 16:22
Sorry for the delay. 1969 Evinrude 25HP. It's actually like this:
The Motor (Model #25902):
PostPosted: 11 Oct 2016, 16:59
ah so, then I would order the kit that you found.
it is the most likely candidate to fit your style pump.
http://www.ebay.com/itm/Johnson-Evinrud ... 3u&vxp=mtr
from this photo, which part are you missing ??
Where is Pappy ???? he does this for a living.
PostPosted: 11 Oct 2016, 19:49
#4 I'm gonna say it should look like this:
PostPosted: 11 Oct 2016, 20:16
oh wow -
how thick was the gasket ? It seems to be just a fiber spacer.
if it was like .020" couldn't you cut one out of gasket material ?
go to the good old E-Bay and search for 0393088 fuel pump kit
PostPosted: 11 Oct 2016, 20:40
I had thought about the gasket material. Would be good to have some around for other projects. I'll check around and see if I can find some. Thank you for your replies ;-)
PostPosted: 11 Oct 2016, 23:03
AUTO-ZONE
Fel-Pro gasket material, 4 assorted types and thicknesses.
Part Number: 3060
Alternate Part Number: 8567
good for all kinds of stuff
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 42 guests
