This is my first boat and motor. I've already learned much from this forum, thanks. My boat is a 1436 Lowe Jon. The motor is a 1984 15 hp Johnson. I use it for river fishing primarily. With a friend and trolling motor and battery my weight is at about the max for this boat--610#. Also I added a Mac's River Runner prop protector. The increased drag from the prop protector is quite noticeable, but considering where I use the boat seems a fair trade. Top speed with this setup is about 15 mph. At this speed the motor seemed like it was lugging so I added a tach to check. The rpm's were 5K give or take. The prop I'm running is the standard 9.5 x 10. Do you think it would be worth the wile to go to an 8, or even a 7. Would it be easier on the motor? Do you think I'd gain some speed? Thanks
