Need help with old motor
63Monark
Arkansas
I have no20170326_132827.jpg20170326_132816.jpg clue on the year of the motor and I have no clue on how to measure if its a short or long shaft motor.I pulled it out of a barn today and offered the lady 80 bucks for it she said it ran when it was stored but I know how that goes. Did I get a good deal?
Sent from my LG-K371 using Tapatalk
Looks like a good deal to me. A little spit and polish and an impeller and off you go.
Hard to be sure from your pictures, but it looks like a 1967 6 hp. ? Model CD-24..
https://www.youtube.com/watch?v=4t5uapnhBbA
manual here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiVwZ2sxvXSAhXH7yYKHR8LD5UQFggxMAM&url=https%3A%2F%2Fislandersailboat.info%2Fwp-content%2Fuploads%2F2015%2F07%2F52138772-Johnson-6HP-1965-68.pdf&usg=AFQjCNHjxrwWzNURUZjbyhqwwy0HX8eGGg&sig2=tc95HOWew1Zva7xNpoEIbQ&bvm=bv.150729734,d.eWE
Well I checked compression today at school 57 on top and 60 on bottom cylinder and it is getting spark because it shocked me when I checked and then we used some ether spray and got it to sputter so I guess I'm gonna take a gas tank and lines up to school tommarow and see how it goes
And check the oil in the lower unit befor you run it. May not have a pee hole to see if water is circulating so keep a close eye on over heating. Great simple bullet proof little engine all it ever wants is lube and cooling.
The impeller is likely to be set and/or cracked from age. Getting in to the pump may be a fight with corrosion, but it will be worth it.
