Motor Seized, Then Magically Un-Seized? 35hp Johnson S.S.
MuskyvilleTV
Hello everyone,
I had my boat out last Thursday doing a little musky fishing. I was just wrapping up the day and driving back to the launch, but I was about halfway back and it just slowed down and shut off. No loud noises, nothing, just slowly lost power and died. I tried pulling it to restart but it was completely seized up. I will swallow my pride a little bit, and mention the boat was loaded down about 150 pounds over suggested capacity, and I was holding the choke in as it goes SO much faster when I do. I do not know if this is a big no-no, or anything about running two stroke outboards, so cut me a little slack #-o .
I brought it to the shop and the mechanics looked at it. They were manually turning the flywheel with the palms of their hands, it would go about 80% of the way around and stop tighter than ****. The term they used was a "spongy" stop to it. They said it was most likely going to be a gear-tooth broke off and was jammed or a bearing busted, in which case they said it would be more expensive to repair than to replace.
I brought it home, let it sit a few days, and just went out yesterday to mope about it, and started turning the flywheel by hand, but the thing went all the way around! I grabbed the rope and it wasnt seized. I quickly drove it down to the river and after about 10-15 pulls it fired up, ran a little tired, but after about a minute it ran just like a watch. My motor has always cold started second pull and first pull everytime after, and had a new impeller put in prior to the season starting.
Can anyone give me their best guess as to what went wrong? By pushing the choke in while running, and going from about 19 to 26 MPH as a difference, did I run it too hot, or too fast to the point the engine wasn't getting enough oil in the cylinders? Again, I'm no mechanic, nor an outboard connisour. Hopefully you guys can help me out! Thanks!
P.S. Motor is a 1981 Johnson 35 Horsepower Short Shaft Tiller
Carb main jet is clogged and making it run lean. Lean burns hot and lean is less oil. It seized and freed up when it cooled. Clean the carb main jet.
Seems strange that a hot seized motor would turn 80% then stop ? Could be something like the mechanic said ... a damaged / bent / jammed driveshaft maybe ?
I'd pull the bottom end first and make sure the driveshaft and lower unit are functional before you try starting it again..
You say the choke was pushed IN??? If it is in, that is supposed to be the way it is. You pull it out to activate the choke. At least on every motor I have had.
Could this be an issue? I found this adjustment today. It is set at the initial setting like the engine sticker says, 1 1/4 turn, which means its running as lean as suggested. Also, I use non-ethylated 50:1 pre mixed in 1 gallon gas cans for this. I run the same gas in my trimmers and mowers for my lawncare business, supposed to be a key to 2-stroke longevity of life.
You are beyond a mere carb adjustment if it runs better with the choke and so lean that it seizes. Clean the carb the right way or do the "poor" mans way like me if it's beyond your ability. Pull every jet, adjustment needle and stuff you can and spray aresol sea foam in the holes. I do that on a ruff runner but yours seized so pull the carb and do it right paying attention to the float level. As far as your premix goes then yes it is different. It has a different specific gravity because it's basically AV gas/race gas. Tweeting your screews should do it but they may wind up a full turn or two from the starting point. Read your plugs immediately after a long wot run. You should change you plugs anyway since it ran so hot. If it's still running lean then switch to pump gas. Also check the JASO oil rating in that gas you are burning. 90% of today's oil are good for everthing but there is no telling what the refinery is dumping into bulk lawn mower premix.
Thanks for the reply,
I think we have some confusion on the choke issue. Choke pulled out is what what would be "choke on" and pushed in is "choke off" or un-choked. I thought my choke was stuck to my motors plastic cover, because I could push my choke in while running, and it would get faster, much faster, and if I were to let go of the choke all the way pushed in, it would come out a bit and slow down by itself.
If you push the choke in it is in the normal run position. It seized in the normal position so you still have a lean condition and if not then that premix is not right. I'd still clean and tune the carb. I don't run any two stroke 50:1. That's the ratio for cruise RPM, idle speed and occasional wide open runs. If you are screaming along for extended periods at WOT then run 40:1. The bone stock race motors from OMC of that era called for 25:1 but they ran a 5500 rpm motor to 7000. I'm not trusting your carb or your gas and since your motor came as close to blowing up as you can get then cover your bases. Id say at least dump a little 2 stroke oil in with the premix but we don't even know what is in that gas yet. And don't pass go until you run a wire thru the main jet. You will blow up 11 seized engines for every one that breaks free and runs again. You got lucky....I hope.
Big difference in air cooled 2 cycle oil and marine (water cooled) 2 cycle oil. You aren't doing your engine any favors running that stuff.
Stump and NC Cat, I have never compared the ingredients in the two different oils
but - I only use Marine 2 Cycle in my outboards - just because it says "Marine".
for the chainsaw and weed whacker, I use the outdoor version - just because it says "Outdoor".
If I can find the suggested OMC 2 cycle oil, I will use that in the OMC motors.
https://www.nmma.org/certification/oil/tc-w3
You see that rating on the marine stuff that says meets or exceeds TC-W3? If you read all owners manuals for two strokes somewhere there will be a disclaimer stating failure to use an oil that doesn't have this will void the warranty. Or any of them made in the late 80's on did.
My understanding is that "marine" oil is synthetic based so that it burns cleaner, with emulsifiers added that allow it to better dissolve in water after it's discharged in the exhaust. I don't think there is a significant difference in the lubrication properties..
From spectro oil in the context of TCw3 oil in snow machines called sleds:
Most of the OEM manufacturers oils are produced by specialty lubricant manufacturers, not the OEM and these formulas are tested and approved by the manufacturer for use in their sleds. The oils are blended according to a formula that has been developed for two-stroke snowmobile engines and this oil is usually given a rating from the American Petroleum Institute (API) of "TC", the Boating Industry Association (BIA) rating of "TC-W", or the National Marine Manufacturers Association (NMMA) rating of "TC-W II." All of these formulas were originally developed for outboard engines and were modified to suit the needs of snowmobile engines; however, motorcyclists that used these oils found that their air cooled engines ran the best on the oldest API TC oils. These API TC formulas contained a higher level of bright stock 150, a high density petroleum base stock with a consistency similar to honey, that gave the best protection against piston seizure and bearing failure. To prevent carbon buildup in the piston ring grooves, these TC oils used metal based detergents that were very effective in motorcycle engines but caused some problems in outboard engines when operated at long periods of time at one throttle setting. A whisker-like bridge could form across the sparkplug gap to permanently foul a cylinder under these conditions while the motorcyclist operating his engine at a constantly changing throttle setting never encountered this problem. When the BIA developed the TC-W rating, they excluded the use of these metal-based detergents in favor of organic detergents to eliminate this problem in outboard engines. These TC-W oils (two-cycle, water cooled) also contained lighter base oils without the bright stock 150. For engines operating in the 4,000 rpm to 5,000 rpm range, the absence of the bright stock 150 had no affect on piston and bearing life. However, off-road motorcyclists testing these new TC-W oils were disappointed with the bearing life of their engines operating at 10,000 - 11,000 rpm and quickly returned to using the TC oils.
The need for a clean two-stroke outboard oil was recognized when piston ring groove carbonization was seen as a primary cause for engine failure and a new formula designated TC-W II was developed. While this oil was significantly better for outboard use and was phosphate free, it still was not the optimum two-stroke oil for engines operating above 8,000 rpm. The phosphate free mandate was from a concern raised by environmentalists that realized that outboard engine use could permanently pollute fresh waterways just as the soap industry was beginning to eliminate phosphates from their products for the same reasons. But, snowmobiles, motorcycles and quads do not emit their exhaust directly into the water, as outboards do. Recently, efforts to develop an even cleaner outboard oil have produced the latest NMMA TC-W3 and this oil, although containing no bright stock 150, has produced better levels of lubricity and cleanliness in piston ring groove areas, however, still not nearly as good as a purely 'snowmobile use' developed oil.
The BIA evolved into the National Marine Manufacturers Association (NMMA) which works closely with the outboard manufacturers. the NMMA mandated that all oils would contain non-metallic detergent additives, no phosphorus or phosphates, if they were to have the approval of the NMMA and the outboard engine manufacturers agreed to recommend only the NMMA approved oils.
Also, many marine dealers were concerned about the flammability and flash point of out board oils. Since larger engines were now consuming huge amounts of oil they had to stock several hundred cases of oil per season. This amount of oil stored in one location had alerted the fire marshals and insurance companies attention and a solution to this risk was addressed by the NMMA. Higher flash point oil with a flash point over 200 deg. F was what they needed to achieve a category 3B fluid rating, just enough to avoid the hazardous storage and shipping restrictions they were facing with all other two cycle oils. Oil manufacturers were forced to use TC-W3 additives or blends with high flash solvents if they were allowed to keep the NMMA license. The high flash solvents caused all sorts of unburned oil problems in engines, but the insurance carriers were happy.The combination of non-metallic detergents and high flash solvents in the new TC-W 3 oils later caused some severe ring sticking in many engines and Yamaha actually required owners to use a 'ring-free' fuel additive to maintain their warranty, a symptom of being forced by the NMMA to recommend the new oils!
This is almost exactly the same situation that developed with the American Petroleum Institute (API) and the Automobile Manufacturers. They were dealing with legislation that mandated exhaust emission systems to last a certain mileage under warranty and catalytic converter failure was known to be linked to the zinc-phosphorus content in motor oils. The API, in response to the auto makers, soon mandated restricted levels of these additives and is slowly lowering them. The problem was that motorcyclists depended on these zinc-phosphorus additives to protect their higher reving motors from damage and they were a victim of a legislation that did not even apply to them (very few motorcycles have a catalytic converter). Now snowmobilers are victims of this exact same legislative situation, the elimination of phosphorus from two-cycle oils. But they do not need to be! Why? Because motorcyclists and snowmobilers can buy motorcycle oils and snowmobile oils and bypass the restrictions placed on automobiles and outboard boats.
Sea-Doo and Ski-Doo didn't go with the NMMA, they refused to allow their engines to be destroyed and recommended to their owners NOT TO EVER USE TC-W3 oils! Polaris bought the TC-W3 sales pitch at first, recognizing an inventory advantage to having only one two cycle oil to be used in their watercraft, quads and snowmobiles. But they soon discovered the same problems many had already found with the TC-W3 oils when used in a sled. Ring sticking, exhaust port blocking and low temperature flow problems. Suddenly all those advantages of the TC-W3 oils they read about from the additive maker's brochures weren't working out when weighed against all the engine failures! Have you noticed they have gone back to purely snowmobile developed snowmobile oils? Currently there are not any snowmobile OEM's recommending the outboard NMMA TC-W3 oil, and there is a reason for this. They are not acceptable in today's powervalve equipped snowmobiles! Only oil companies with little actual knowledge of snowmobiles and their specific needs continue to try to sell snowmobilers an outboard oil for their snowmobile...and this is because they have a vested interest in doing so...economy of scale by combining several markets into one and selling just one oil. Do not fall for their sales pitch!
In Japan, engine manufacturers have developed a series of strenuous engine tests that can identify poor quality oils if they don’t measure up in performance. They tested over 250 samples of two-stroke oils worldwide and used the survey results to establish these engine tests. This became the JASO classification system. (Japanese automobile standards organization).
The tests include a detergency test, lubricity test, initial torque test, exhaust smoke test and exhaust blocking test. These tests have a much closer connection to actual snowmobile engine applications compared to TC-W3 tests which are all conducted on raw-water cooled outboard engines. And for the first time ever, an oil can fail the test if it smokes too much!
The detergency test evaluates the oil’s ability to maintain the cleanliness of critical engine parts, including exhaust power valves. This is very important on power valve equipped Rotax, Yamaha and Polaris engines. The lubricity test measures two things. First, the engine is run with a load for 50 minutes then the cooling system is disconnected for ten minutes and the resulting drop in horsepower is recorded. This cycle is repeated several times and each drop in power is compared and it must not vary more than a specified amount or be more than a specified amount. Then the engine is run with increasingly leaner oil ratios: 60:1, 100:1 then 150:1. If no seizure occurs and power is maintained within a specified percentage, the oil passes. The initial torque test measures the engine’s startability when cold, an important consideration for 3-cylinder sleds.
The exhaust blocking and smoking tests are run by mixing the test oil at an over-rich 10:1 ratio and running it in a two-stroke portable generator. The exhaust is channeled into a chamber where a photo cell measures the light that can pass through the smoke. It sounds crude but it works! Finally, a real world test to measure exhaust smoke from two-stroke engines! The exhaust blocking test simply examines the pencil sized exhaust outlet for carbon blocking. At a 10:1 ratio, these tests are very hard to pass. The highest JASO rating is FC. Lower ratings are "FB" and "FA." An even higher "FD" rating could be seen in the future. Most TC-W3 oils will not pass any of these tests!
In Europe, European two-cycle engine manufacturers were simultaneously working on two-cycle oil tests to separate the cheap, poor quality oils from the top quality oils. They tested the JASO reference oils in European engines and their top reference oils in Japanese engines. They found that European two-stroke high performance engines needed an oil with a better detergency and higher temperature performance than the best JASO "FC" oils. In April, 1997, they published their ISO global standards for two-stroke oils with two quality level categories: ISO-L-EGB and ISO-L-EGC. The ISO-L-EGB aligns closely with JASO "FB" and the ISO-L-EGC aligns closely with JASO "FC" for minimum test standards. Then, they developed the "GD" detergency test to run hotter and longer (3 hours vs. 1 hour) than the JASO detergency test. Oils passing the new ISO quality level, ISO-L-EGD would be superior to any previous two-stroke oils available! Of course, it didn’t take long for oil manufacturers to develop and test oil formulations that pass this new quality test, and most of them involve using synthetic base oils. Running these tests is a very expensive and time consuming effort but in the end, a bottle of oil with one of these JASO FC/ISO- L-EGD certified ratings means that the oil meets the highest quality tests set by the engine manufacturer in Japan and Europe.
Polaris, had recognized the "all-in-one" advantages of TC-W3 two-stroke oil, and recommended the use of TC-W3 oils in their watercraft, quads and snowmobiles for several years, have recently taken Ski-Doo's position....don't use it! Basically, specially formulated snowmobile oils that pass JASO FC/ISO-L-EGD and do not follow NMMA outboard engine additive restrictions will provide much better protection for higher rpm applications (snowmobiles generally rev higher than 6,000 rpm) and still provide a superior lubricity and detergency than TC-W3 oils at the same cost with less smoke. So, use snowmobile oil in your snowmobile and outboard oil in your outboard engine.
The " Top End" manufacturer oils are syn based.
BRP, for example uses three different oils. The 30 can be either a mineral or petroleum base, the 50 is a blend of syn and the base oil. the 100 is a pure synthetic.
To the OP.....if you are using your weedeater oil in your outboard you have and are making a mistake. Use only an outboard lubricant. Manufacturer oils usually will be recommended here but use what you want. In a BRP oil I would use nothing more than the base "30" oil.
Now....Your engine stuck. Period. Damage has occurred.
Why it would only rotate 80% through needs to be looked at as it will rear its ugly head again.
By "Stuck" I mean that. if it is a piston stick, at the least, then your exhaust side of the piston skirt and possibly the intake side as well will have damage. Your engine is a cross flow design so you may see damage at the upper edge of the deflector and or burning at the edge of the piston. You should see scuffing of the cylinder wall. Check the exhaust sides first.
You need to look at this before simply putting the engine back into service. The carb definitely should be looked at. The fact that the choke system is not staying in the off position needs to be addressed as well. On that particular engine I believe it still had the upper plastic water tube connector which has/had a nasty habit of melting and restricting water flow at or near WOT. Yes, you would see normal flow at an idle from the overboard indicator.
There are small, effective "bore scopes" that can be attached to a cell phone for looking at the inside of a cylinder bore now. They are cheap and pretty good. Photos can be taken of any particular area with these as well. Here is one example...there are tons to choose from. https://www.amazon.com/Endoscope-Depstech-Inspection-Megapixels-Smartphone/dp/B01MYTHWK4/ref=sr_1_1?ie=UTF8&qid=1498701527&sr=8-1&keywords=borescope
