water bouy
I'm going to extend the shift lever on my 1985 30hp Mariner if I can figure out the bolt size on the right side of steering bracket if anyone is familiar with it. I ordered a rod bearing per the article below and a 12" aluminum tube from onlinemetals.com. I'll use a knob instead of a tee handle.
This is the article:
https://www.sailmagazine.com/diy/outboard-boat-motors-diyoutboard-shifter/
