2004 mercury 9.9 pro kicker 4 stroke --no water
randyo3629
peru, indiana
little water spitting out at low engine speeds.
rev up and it starts flowing good.
worn water pump impeller?
easy fix?
thanks
Bought an 08 Tohatsu 20 hp not long ago. Exact same symptoms. My other motor is a mid 80's Jonson 15 hp. It's stream from the water pump is not all that vigorous. But I was suspicious of the Tohatsu. I tore it down and found the impeller was both cracked and worn. I replaced it and found the the pee stream started very quickly at idle and was much stronger than before.
As for degree of difficulty--I'd give this job about a 3 on the 1-10 scale. The biggest issue on my motor was that in order to disconnect the shift linkage I had to remove a tiny pin by tapping it out with a tiny long straight object of a slightly smaller diameter. Found a drill bit that worked and the rest was pretty straight forward.
I found a U Tube video that helped.
If in doubt replace the impeller, much easier than fixing a overheated top end!
Was it running well and then stopped flowing a lot of water, or is it new to you so you don’t know the history?
I just replaced the impeller in a 3.5 Johnson, and it flows well even at idle.
