RaisedByWolves
Evenrude 25hp 1996 22" shaft.
I got a lil over enthusiastic removing the lower unit and snapped off a 1/4-20 bolt.
No big deal as Im a toolmaker and have removed hundreds of broken bolts.
Im trying to remove the long shaft...uh...Spacer? dont know what its called but the stud in the front of the lower spacet thingy unit wont budge.
This bolt.
I got the other 4 out no problem, but the spacer just rotates around this bolt without the bolt turning, its corroded in place. Pretty sure I could unscrew the end thats in the spacer if I could rotate it 360 and get it off that way, but the shift rod is in the way.
Im using "Eds Red" as a penetrant but wonder if heat would hurt anything.
This bolt.
