Have a 25hp 1996 Johnson. J25RMEDC. Steering is a bit loose, so I tried tightening the bolt under the cowl but seems to have kind of bottomed out and still not tight enough. Is there a friction block or something I need to change?
I've never had to on an omc motor.. and I have motors from 1971Frank29 said:thank you gypsy400. i see there is a bolt and a friction block, block must be worn. is that hard to change?
