Motor selection
Hey folks. First ever post on this forum. Looking forward to learning as much as possible in here. After searching around on here and reading some posts I want to ask for y'alls opinion.
I've got a line on purchasing a G3 1548 with a metal floor and gunnwal kit. Front deck, three trolling motors, batteries and chargers on each. I plan on removing the two rear trolling motors and leaving the front one. I want to add an outboard. I'm thinking a 25 or 30 horse tiller. I plan on adding a kick up plate. Possibly even a jackplate. I will use this boat in the lake and river. I will fish and hunt out of it.
1) what motor would you folks recommend? I'm leaning 4 stroke simply for noise. Have any insights on this?
2) where or who has the best prices on motors?
3) should I consider anything for this "build" that you did and i absolutely must do?
Thanks for any help!
Yamaha four-strokes seem pretty popular around here. I have a Honda four-stroke because that was part of the package deal. So far I like it a lot. No problems at all with it so far with a little over 200 hours on it. I also previously had a 25 HP Merc four-stroke that I found dependable. It was new when I got it so I know it was maintained. I don't know about older 2-strokes.
I do as much of the servicing as possible myself, but still like to know there are local shops that can wok on my brand.
new or used? what are there for dealers in your area and do you plan to fish local, mostly? for 25/30 i'd go tohatsu or etec.tohatsu for value and etec for ease of maintenance,plus power.nothing will out pull an etec.i've got over 300 hours on my 40 and i haven't done a thing to it,it's more efficient,quiet,it winterises itself,and i got a 10 year factory warranty.lets see if yamaha will match that.let the fights begin.
Lots of variables...First off what is the boat rated for and what is your budget if you are willing to buy a new outboard?
Thanks for the replies.
Budget is the best bang for the buck. But I'd like to keep it under 5k or 6k. I want electric start and built in tilt. Guess I could go used. But ideally new. I have lots of dealers around me. I'm sandwiched between lake Lanier and lake Allatoona here in Canton GA. So there's plenty of dealerships around. I've found that dealerships only want to sell you A) what they carry and B) what they have in stock of that motor they carry. Regardless of what you want...... Is there not a direct on line source for motors y'all know about? Boat is rated for a 25.
Your last sentence in your last post opens a veritable can of worms.......
What you need to do is establish a relationship with the dealer of your choice.
In the horsepower range you are looking at there are very few choices in power as quite a few of the engines are built by a single manufacturer and re-branded.
Now for the can of worms...... When you buy an engine online and then have an issue with it you will have to take it to a local dealer. You know, the one you did not buy it from? Guess where you will be placed on the work flow list? That is correct, behind all of his in-house customers. Last on the list.
Just something for you to think about. Always nice to purchase local and keep your money local.
Pappy, you raise a good and smart point. I need to order this set up from a brick and mortar near me. I hadn't thought that point through. Thank you for setting me straight on that.
Does anyone know if the recent year model etecs have solved their impeller issues? I've seen some reports that the material isn't holding up guys are having replace the impeller out of pocket since it's not covered under their warranty.
We saw failures for a while on the impellers but that issue seems to have gone away. Talk to your local dealer as well and verify or see what they say about it. Was a known issue and usually it doesn't take long to identify and rectify the issue but longer to rid the existing inventory and get existing customers taken care of.
Forget ETEC. Too heavy, too expensive. They run nice, and they are quiet-and that is their only attributes. They're heavier than the 4 stroke motors.
Yamaha 25. I have one. Read the review I did on it a while back. Love the motor, and it's lack of weight. It's 10lb heavier than the 2 stroke 25 twin carb and about 15 lb lighter than my old 3 cylinder 25. Sips fuel. quiet. GF and I hold conversations all the time while running the river here but at full throttle I can't hear her very well because her voice doesn't carry very well. My dad, though, we can hear each other just fine. 1548 war eagle, rated for 40hp. If it weren't a short transom, I'd have just put a 40 on it and been done. Yamaha don't make a 15" 40hp other than a jet and I am not having a jet on this boat. There is only one complaint I have out of the current 25hp, when new, it shakes a little at idle. It subsides mostly after about 40 hours use, that or I got used to it. I haven't noticed it much lately, got about 45 hours on it now.
When you say you want built-in tilt, do you want power tilt? That limits your options. Is your hull 16" or 20" (short or tall) transom? The reason I ask....Yamaha does not make a short shaft power tilt 25hp. You have to get a 25hp remote steer long shaft with power tilt, then buy/install the tiller kit (which is big, really big and IMO bulky), which adds considerable cost to the motor. I want to say it ends up about $4500 by time it's all said & done. I ASSume your 1548 is tiller steer right?
Suzuki makes a decent motor too but I wasn't that impressed with them. Lot of people like them but for some reason they are not popular here. Only one or two dealers in the entire state, that is one problem. Other is that Suzuki doesn't advertise much, they have had internal issues at one point and about bankrupted them. Don't know if they ever recovered. To me, that doesn't show stability--and by golly if I'm spending a ton of money, I need to know that the dealer and the company are going to be around for the duration of the warranty.
So that leaves Mercury, Nissan, Tohatsu. They are all the same exact motor but with different decals and paint color. Stay away from them. Heavy as an ETEC 25 and slower. While they are smooth and quiet, the lack of torque was FAR from impressive in my opinion. Also mercury does some really weird stuff with their products and those who know mercury products well all say that everyone else is different....take that however you want. I have a 40hp EFI merc in the shop that I can't figure out, merc can't figure it out, their tech support is nonexistent, so I'm back to throwing parts at it, all the while every single bolt that screws into the powerhead has broken off (freshwater only mind you and occasional use only). I've never once had a Yamaha bolt break but then again I've not had to work on many of them other than carburetors on the old ones.
If you put a jack plate on it, that'll let you run shallower and potentially faster. On mine, with a manual jack plate, I have seen consistent 32 mph but it needs more prop as it's on the limiter. Might run faster/higher with different prop.
Yes definitely use a local dealer for the reason that pappy mentioned! I can't tell you how many times people have brought motors to me with questionable "warranty" repairs, bought online but never had the PDI done and warranty registered. If it's not registered, it doesn't have any warranty and secondly if they don't buy it at the dealer, they are subject to going to the back of the line. If one of our customers has a problem, he spent his money with us and he comes first. Nobody makes much on outboards so many dealers are multi-line, meaning they'll have other equipment, and their customers always come before mail-order customers, so in a multi-line dealer the wait time for repair or service can be lengthy. I don't know about you but I hate missing a day of fishing for stupid stuff like that....particularly since I only get 1 day off every few weeks.
bcbouy said:
so,an etec weighs more than a yamaha? really.187 vs.215 w/o power tilt .check your facts.
Are you talking 25hp models? I think the new EFI Yamaha 25hp weighs under 140lbs.
Since you say 25hp is the hull rating, I would scratch the kick-up plate from your wish list. Most 25hp models will have the manual tilt pin, so if you mount the motor on a jack plate or aftermarket trim unit you can leave the motor's manual tilt system unlocked which allows it to swing up if you hit an obstacle at slow speeds just like a kick-up plate.
Are you sure you didn't look at the 40hp? Yamaha's 40 is a heavy pig at 215 lbs, but I did not speak of 40hp, I was talking about 25hp and there is a HUGE difference. 40's are real popular here too, mostly 40/30 jets. VERY common along the rivers in this area, outnumber the Mercury suzuki tohatsu evinrude and johnsons combined.
Yamaha F25SWHC is 130.5 lb (my motor with fuel in the VST. The short shaft manual start version is 126 lbs even, dry (out of the crate). I don't see many of those here. $3789 at work, just mounted one a little bit ago and pulled the tag off. Need picture?
ETEC comparable (tiller electric manual tilt short) 166 lb even. $5050 online.
I like the etec but I am not impressed with their lack of longevity. If they could make it more reliable and less costly, and most importantly lighter, I'd consider owning one.
Those are on my shipping scale at work. ETEC 25hp is a lot heavier. It's heavier than the suzuki, heavier than the Tohatsu/Mercury/Nissan and those things are pretty big/heavy. Now why on earth....does an ETEC have 577cc, the yamaha (which is 4 stroke) is only 432cc, and the mercury/tohatsu is 500cc, and they all make 25hp?
Common issues that have been seen in this area with the etec 25hp have been high pressure fuel pumps, impellers, and the most inconvenient is when sand/dirt/stuff gets stuck inside the cooling tubes that reside in the EMM, which makes the EMM get warm, which throws it into limp mode. The worst part about this is that the operator never notices a lack of telltale (pee hole) water. The EMM is about $600, warranty usually picks up the tab on failed ones but not so much on the liquid cooled/plugged cooling hose ordeal. Pretty common. EMM is the engine management module, aka computer. On the impellers, I am understanding that BRP has improved them for the newest generation. I haven't heard on the EMM cooling. No solution that I know of (or have heard of). HP pumps are said to last longer if you mix a little bit of oil into the fuel. Defeats the purpose of having oil injection doesn't it? Also...on the oil injection...you MUST run ETEC's specific oil in the ETEC motor, unless you have it reprogrammed then you can run whatever you want. That almost sounds like the Volkswagen diesel ordeal if you ask me.
People talk about the "simplicity" of a 2 stroke and supposedly that is the ETEC's main selling point, but what they don't tell you is how much more complex the engine's fuel and operating systems are in comparison to a proven, tried and true EFI 4 stroke. Yamaha's system is really simple. I was a skeptic too, but I bought one anyway and everyone I've talked to has had exactly zero problem with them. That is impressive in my book. ETEC guys? A few are happy. The rest have already sold them or are trying to. I have a neighbor and a family member-both in the same situation.
One other consideration is the shipping costs if one was to purchase online. Most everyone charges a flat rate to anywhere which is LTL (less than truck load), it comes on an 18 wheeler. A lot of the time they (shippers) negotiate a price with the cheapest place they can find and those cheap places aren't always any good. I deal with them daily. XPO is just ok, R&L, nothing comes in one piece, Southeastern Freight, everything comes completely torn up most of the outboard crates come with no cardboard on them (just Styrofoam and they tape it up). Southeastern is probably the worst. AAA cooper is one of the better ones but they also cost more. UPS freight is ok sometimes, other times not, other times stellar. Same with FEDEX freight. But most companies use the least expensive which is almost guaranteed to get you a torn up box. Whether the motor is hurt underneath the box is a case-by-case basis. Regardless, if it is skinned up (cowlings broken or scratched up is common, also scratches on the leg and sometimes the foot), then you get to fight with the people you bought it from, with the freight company (which can be a nightmare), they will want pictures and they know what they are looking for, so just any picture ain't gonna work in a claim. Sometimes the shipper (company you purchased from) might want you to return a part that is damaged. If you aren't a mechanic or have mechanical skill, you have to pay a shop to remove the skinned up part, pay to send it back, hope it gets there and hope it gets there in the same condition you sent it. The whole ordeal is a nightmare! And to add insult to injury all shipments that are heavier than I think 40 lbs have a $20-something dollar fee tacked onto them, and truck freight charges went up too (particularly LTL stuff). I ordered a hood for a car a couple week ago and it was over $250 just for shipping (again, LTL) but it came in perfect condition via fedex freight. I could have gotten it cheaper from Roadway, XPO or even souteastern but I chose to use fedex instead, easier to deal with, better equipment, and these guys around here take better care of their freight than the UPS freight (local) guys do. And on a freight damage claim, most of the time Yamaha doesn't actually "cover" that as a warranty deal because it's not their responsibility; they do a pretty good job of inspecting every crate that leaves their warehouse, once it's on the truck, damage responsibility falls solely on the trucking company, and they do everything that they can possibly do to get out of paying for damage. Trust me, I deal with on an almost daily basis.
This is the boat I am looking at buying from my brother in law. I was hoping I could stick a 30 on it but it appears that's gonna be too much of an issue so it would need the 25 Yamaha.
I've ruled out the Etec.
(((((((When you say you want built-in tilt, do you want power tilt? That limits your options. Is your hull 16" or 20" (short or tall) transom? The reason I ask....Yamaha does not make a short shaft power tilt 25hp. You have to get a 25hp remote steer long shaft with power tilt, then buy/install the tiller kit (which is big, really big and IMO bulky), which adds considerable cost to the motor. I want to say it ends up about $4500 by time it's all said & done. I ASSume your 1548 is tiller steer right?)))))))
Yes. I want a power tilt motor. I do not want to have to reach back and tilt it up manually. I'm headed to the boat show in Atlanta this weekend and hope to get a better grip on the motors in this size range. I feel a little outclassed here in this conversation lol. I honestly didn't realize so many motors in this size range were so different in features. Also, you aren't the first person to tell me to buy a Yamaha. I've heard it from 10 people if I have heard it from one. The boat I am looking at was purchased by an older fellow that ordered it set up for reservoir fishing. Three trolling motors, (2rear 1front) a bunch of batteries and chargers. So IF I buy it I would be removing the two rear TM's and putting on a gas motor.
I'm starting to think the features I want in a boat and motor are meaning I may need to step up to a different boat with a different motor set up altogether.
That's a 16" transom, requires a short shaft motor.
Yamaha doesn't offer PTT on a short shaft F25.
Suzuki may be an option for you:
https://onlineoutboards.com/collections/suzuki-outboard-motors/horsepower_25hp+shaft-length_15-short+trim-and-tilt_power-trim-tilt
The three main aftermarket tilt and trim units are CMC, Panther, and Bob's Machine. The basic models each sell that offer tilt and trim for 30 or so hp motors is about $650. Bob's has a versa jack combo that is a hydraulic tilt and trim unit with a manual jack plate built in but it is $1,250. TurboTodd may have an opinion on this topic too. I get the feeling Bob's seems to preferred by the Arkansas duck hunters where he is from.
I'm not sure what extra cost is to add tilt and trim from the factory, but one benefit of having the aftermarket unit is that it is semi permanently mounted on your boat so you can swap motors or play with the motor mounting height without much hassle. One negative is they provide a lot of setback - which is good in a sense as it allows you to run the motor higher - but if you dont get one with a built in jackplate you then have to stack a trim unit and jackplate together and the setback starts to become ridiculous.
as said, yamaha doesn't have a short shaft (tiller OR remote) with PT&T. Unfortunate, or I'd have one.
But....
out in duck country, they run 25's all the time (and 40's, 50's, 70's, and I know of at least one with a 90 on it) on 1542's 1548's and 1556's. Bunch of 1552's too. Some of these guys are more interested in racing than hunting, but whatever. Not my cup of tea racing down a ditch just wide enough for 2 boats, going about 40 knots, bouncing off of each other, then getting out into flooded timber at 35-40 kts trying to avoid knocking yourself out of the boat.
Anyway...
Yeah bob's, Atlas, and CMC (CMC and TH marine are owned by the same parent company IIRC) are the most popular. CMC (and TH) being more popular than Bob's because they are all self-contained units where Bob's for a long time used a remotely mounted pump. The new Action series is self-contained, however. The downside (to the CMC and TH-marine) is the stupid dual relay system and all of the wiring, but the new stuff has better relays than the older ones did. Also the PT-35 is ok until you hit something underwater, and at that point the lower clevis usually breaks off. Stupid design and well documented all over the web. Most of them are ok, but if you're one that hits stuff a lot, you'll probably bust it. The good thing about the add-on PT&T is that you're not tied to just power tilt. Tohatsu (at least the 20hp) is power TILT only (not trim). I think Suzuki is too. In other words, it will not tilt while underway, at least not with any appreciable throttle input. That's why it still has a trim stop pin (or bolts in some cases), that is your trim but you can tilt with the button. With the setback of the add-on plate, most folks can raise the outboard about 2" without any issue (in other words the av plate ends up at roughly 2" above the bottom). I have gone higher, depends on the hull. Now with the set back, the tiller is going to get "shorter" (motor gets further away from you), so if you choose that option, look closely at the brands of motor you're looking at--the suzuki tiller is a little shorter than Yamaha, and the Merc /tohatsu is somewhere in between. I think the Yamaha F25SWHC combined with a CMC PT35 is going to be the hot ticket, and you may have to pick up a 12" pitch prop as the factory 11 1/4" may be a little unhappy with the setback and height combined with more speed. Might see 30+ mph out of that setup.
If you want a jack plate, and have some $$$ to burn, look at the Tilt-n-jact from bob's machine. Expensive but gives you a jack plate and PT&T all in one. Only bad part is that the pump is remote, so you have to mount it in the motor well which takes up space.
Another thought before I go back to the shop....with the Yamaha combined with a PT35 (or even PT130), you can put the PT&T switch anywhere in the boat you want, BUT, my suggestion is to pick up a tiller throttle grip from a Yamaha F40, and the switch, and put it on the F25, so you have a factory tilt built into the tiller grip. Makes for a nice setup. If I'm doing it, that's what I will be doing, plus doing away with the dual relay setup and going to an atv winch contactor, which greatly simplifies the wiring. It costs more to do it that way but it's WELL worth it!
Also with the CMC/bobs/Th-marine PT&T combined with the manual tilt 25, you can unlock the tilt and it will flip up if you hit something. With a standard power tilt motor, it will still kick up but it takes a LOT more force to make the valve go into relief. I mean a LOT more (like knock yourself into the drink more). Additionally with the CMC/TH-marine/bob's, it gives you about 3 degrees of negative "tuck" (trim "in"), which helps you get a heavier load on plane. That is a nice feature. With a manual tilt motor, you set the pin for best speed but you generally get a good bit of bow lift while getting onto plane, sometimes if loaded just right, it won't even plane at all until you move the pin "in". Or you move the pin all the way "in" (down) and get on plane fast, but lose a ton of speed. There's not much in between. With the PT&T (add-on, not OEM), it gives you more tuck, you hop up on plane, then hit the switch to trim "up", and watch your speedometer start climbing and your fuel usage go way down. They are a win-win and that's exactly why they're popular out here where guys will have 3 or 4 guys their dogs their guns, a half ton of shotgun shells, decoys, blind(s), the kitchen sink, enough LEDs to light up the entire city of Dallas (including under-gunwale green or red accent lighting), 14 gallons of fuel, 3 or 4 batteries, jackets, camo clothing, and a bunch of other stuff, all in the same 15' boat, wonder why it won't plane with 25hp, so they stick a CMC on it and tuck it in tight, plane off (struggling) and then trim it up. It works good. Notice....that list didn't mention first aid kits, rare to see one on a duck boat, but it should be in there!
