I'm working on a 2002 Johnson 25 hp 2-stroke. It came with a boat a just picked up that had been sitting a while so I don't know much about its history. I'm going through it trying to get it back up and running - but I'm having a problem I just can't figure out. It then runs fin for about 10-15 minutes, but then the water stops coming out of the tell tale and it starts to overheat. Also, it takes a bout 20-30 seconds after start up for water to start coming our of the tell tale when I first start it cold.
The first this I did when I got the motor was replace the the water pump (housing, impeller, etc). What would cause water to stop coming out of the tell tale once the motor gets hot? I'm thinking it may be the thermostat so I have one on order just in case, but I don't want to throw parts at this. If I let the engine cool off, the water will flow correctly again, but once it heats up it stops. I know my way around engines pretty good, but I'm new to outboards. Any help would be greatly appreciated. Thanks in advance!
