Good day,
Could appreciate a bit of advice.
Setting up a tack on my Evinrude 70773S motor.
I’m using the Evinrude tach cable that connects into the control box.
I thought things would be simple but as usual they are not.
Wires from the cable are connected correctly to the tack and plugged into the control box but nothing is happening.
Because the cable is a bit old I checked each prong of the tack cable and there is continuity from one end to the other.
I then opens up the control box and plugged the cable in and there is connectivity from the tach to where the black, grey and purple cable originate in the control box.
So my questions.
1. With the motor running what should the voltage be across the black and purple cable in the control box? I am assuming it has to be greater then zero.
2. Is there a way to check that the grey wire in the control box is providing a tach signal?
Any other troubleshooting suggestions?
Appreciate the help.
Alex
So my questions.
Alex
