Tilt Pin
evattman
Middle TN
So, my Evinrude 35 did not come with a tilt pin/rod. Ive looked on Ebay and everywhere else I can think of and cant really find one.
Any one got any ideas about what I can use/buy/build that would safely work?
This sounds like a job for
da da dah dum de!!!!!!!!!!!!!!!
BASSBOY1
Try this site to find the part number. https://epc.brp.com/ You can look at schematics of your motor. When you find the part number you should be able to find a place to order a replacement fairly cheaply.
i would get the correct part but I have seen people use those small pins that can be purchased at hardware stores.They're L shaped with a little ball on the end to keep it from sliding back through.
go to crowley marine web site and go through the picts of which motor you have and order the right part not expensive and the right part is always the way to go
