Kenda tires-where do you rate them on quality?
Houndlab
Read some good things about them but have never had them. What do y’all think about them?
I starting my 3rd season on these 12" load range C Loadstars and they're great. No complaints at all. They've even seen some 2-hour trips at 65+ mph and then gone offroad for a mile of rough fist-sized gravel and then over the bank into the farm lake. My 1648 is heavy with added decking, carpet, 3 60-pound batteries, a Maxxum 70 and all the junk I take.
www.etrailer.com/Trailer-Tires-and-Wheels/Kenda/AM30820.html
Fwiw, they came inflated, but not to 80 psi. I always run the max.
I've had a couple sets of the 12" load range C. Good tires.
Recstuff.com will be the cheapest. Ordered from them a bunch and had them in two days
Thanks for the input fellas. Johnbt, everything I’ve read says to keep psi at max for best performance.
Midwesterner, good looking out on the website-I’ll check them out.
I run mine at 70 psi, I think they max out at 80 psi. You will need metal valve stems rated for the pressure. Not all metal stems are rated the same.
I've bought them on the rim mounted from Recstuff for around $60 shipped.
