Utility Trailer to Boat trailer?
theyyounggun
Central, AR
Im tryin to find a boat trailer but cant find one for the right price. Im gonna keep looking but could I use a normal small utility trailer and put boat trailer lights on it? I would mod it to be like a boat trailer.
if going through harbor freight i would get one.of the utility trailers around 1200+ lbs capacity and add a longer tongue to it. assuming its gonna be freshwater only
theyyounggun said:
So it would work? I was just wondering about the grease in the bearings
Should work for ya, although the quality isn't the best. You can always repack the bearings with a better quality (marine grade) grease and use bearing buddies. The buddies should be like a $25-50 upgrade...I think that they even sell some @ Harbor Freight for $15-$25.
I built a utility trailer out of my northern tool boat trailer. Sold my jet ski. Guy didn't want trailer so I added some metal and wood. Just add bunks and may have to cut railings off and u have a boat trailer
I use a utility trailer for my 14' jon boat. I don't dip it. I slide the boat off into the water and pull it back on. I only run an electric trolling motor so the weight is not that bad.
