Trailer Painting
Trailer related issues and discussion goes here.
jt25
Trailer Painting
Post by jt25 »
How did you guys paint your trailers? Rattle cans, rollers, paint gun?
My build: https://www.tinboats.net/forum/viewtopi ... 21&t=29651
Work is for People who don't Fish!!
lckstckn2smknbrls
Trailer Painting
Post by lckstckn2smknbrls »
I did mine with brush and spray can where I couldn't get the brush.
BrazosDon
Trailer Painting
Post by BrazosDon »
X2 here, bro. A cheap brush, a quart of Rustolium, a spue can in the same color, and no clean up.
Stickicker
Trailer Painting
Post by Stickicker »
I used the POR15 brush on system and it turned out fantastic. I was amazed at how it smoothed out. Looked like it had been shot in a paint booth. It has only been on for a year but no rock chips so far. We have been on quite a few gravel roads with it too.
parkerdog
Trailer Painting
Post by parkerdog »
Like the others said, brush/roller then rattle can for the nooks and crannies/corners. (international tractor red. just so I'll remember the color for touch up which I do need since I tried to park the boat on the fender last year.)
1860 tracker grizzly (work in progress)
jt25
Trailer Painting
Post by jt25 »
Thanks for the info guys!!!
Charger25
Trailer Painting
Post by Charger25 »
BrazosDon wrote:X2 here, bro. A cheap brush, a quart of Rustolium, a spue can in the same color, and no clean up.
lckstckn2smknbrls wrote:I did mine with brush and spray can where I couldn't get the brush.
Yep thats what I did ,after using a wire wheel on an angle grinder.
Even welded on some side guides
12ft ryancraft w/ 8 hp Frankenstein rude
14 ft fisher w/ 15 hp rude
16 ft lowe w/ 25 hp Frankenstein rude
9.9 Rude / sleeper
6 hp Evinrude Sail Master
Hanr3
Trailer Painting
Post by Hanr3 »
Rustoleum rattle can, black hammered finish. :mrgreen:
It's all in the prep work.
HOI Crappie Club
Where family and friends come to compete for a little more than bragging rights.
'97 16' Sylvan Back Troller Select
'67 14' Alumacraft
'57 Model FD11 18-hp Johnson Seahorse
'09 Traverse FWD V6 w/ towing package, power sun and moon roof, and ton of other options. The only one I wanted was the towing package. :mrgreen:
Stove Iron
Trailer Painting
Post by Stove Iron »
Like it was said earlier, whether you rattle can it, spray it, roll it, brush it, whatever, be sure to spend the extra time on prep work.
I bought an old v-bottom bass boat trailer to use for my 1652 Alweld. I extended the trailer tongue and added some horizontal braces for the bunk board frames. It had lots of bubbly surface rust, but a knotted wire wheel on an angle grinder made short work of that mess.
I make my own wax and grease remover. It's 50/50 mix of Acetone and Denatured Alcohol used by a lot of older street rod guys. I used that mix to wipe down every inch of that trailer frame then used a brush to spread Sherwin Williams KEM Kromik Primer into the corners. I then sprayed on the primer and then gave it plenty of coats of Gloss Black KEM400 enamel. It's been holding up well sitting outside in the southern weather for a few years now.
Sherwin Williams KEM400 paint works well with rollers too. If you thin it out a little, it levels out into a smooth finish. If you like that wrinkly wavy look, just roll it on full strength.
BrazosDon
Trailer Painting
Post by BrazosDon »
Responding to Stove Iron, what difference does it make unless you are going to comb your hair(?) in the shine of the paint. lol
Matt Creed
Trailer Painting
Post by Matt Creed »
jt25 wrote:How did you guys paint your trailers? Rattle cans, rollers, paint gun?
Rustoleum brand undercoating. Works like a charm. I've used it on two trailers so far.
J.P.
Trailer Painting
Post by J.P. »
leftover enamel over metal primer, slathered on with a good old paint brush.
Colbyt
Trailer Painting
Post by Colbyt »
Rattle can for the coil springs. Rusty metal primer on the whole thing and two coats of flat, slightly thinned Rustoleum all applied with a brush. I choose flat because even after all the prep work gloss would show way to many imperfections.
I found 80 grit paper and a palm sander to be a lot easier to control than the angle grinder with a wire brush though I used them both depending on the area.
Colbyt
Stove Iron
Trailer Painting
BrazosDon » 17 Apr 2013, 22:34 wrote:Responding to Stove Iron, what difference does it make unless you are going to comb your hair(?) in the shine of the paint. lol
IMO, it makes a big difference regarding ease of clean up and durability.
For example, go paint one car with a flat finish and another car with a high gloss finish. Park both of them out in the elements and let them weather a few months. Come back and tell us which finish has more dirt, mildew formation, debris, lichens, etc. on it. It's the same principle as sanding the primer coat in preparation for the application of color coats. The "scuffed" up surface promotes better adhesion than a smooth surface. Whereas a glossy surface helps resist such adhesion.
But, in the end, it all comes down to owner preference and possibly budget constraints. To each his own.....
Scott06z71
Trailer Painting
Post by Scott06z71 »
About how much paint would it take to paint a trailer for a 14 x 36 Jon boat? Do you think a quart would do it? I'm thinking of using my wagner electric sprayer.
2014 Tracker Topper 15 / w 2014 20 hp Mercury
