transom saver.
Trailer related issues and discussion goes here.
hipster dufus
transom saver.
Post by hipster dufus » 30 Jul 2016, 09:24
where on ur lower unit do u place ur transom saver? above the cavitation plate or below it? does it make a difference? just wondering
lckstckn2smknbrls
transom saver.
Post by lckstckn2smknbrls » 30 Jul 2016, 15:25
I put mine below.
DaleH
transom saver.
Post by DaleH » 30 Jul 2016, 20:19
hipster dufus wrote:where on ur lower unit do u place ur transom saver? above the cavitation plate or below it? does it make a difference? just wondering
FWIW the guides & guys I know who "chase" tuna - from launch ramp location to launch ramp location - who are all trailering 24'+ deep-V center consoles w/ no less than 250hp motors ... DO NOT use 'transom savers' but use that 'My Wedgie' thingie that affixes to the trim/tilt rams.
Check it out - see: http://www.m-ywedge.com
Let me tell you ... these guys are Pros and use nothing but the BEST!
#4 Procraft SV14
perchjerker
transom saver.
Post by perchjerker » 31 Jul 2016, 07:23
the My Wedge is different. I know people who use them
they are intended to protect the hydraulic trim/ tilt components, the stress is still the same on the transom
I use the same transom saver on my 24ft Grady White with a 200 Johnson as I do on my 14ter with the 9.9 hp
not only does a transom saver relieve the stress on the hydraulic components it helps protect the transom as well
mine fits both boats so it works double duty
as far as above or below the cavitation plate is doesnt really matter, whichever fits best
transom savers is one of those things people seem to argue about for whatever reason
All I know is I have used one on every boat I have owned (starting in 1978) and have never had a problem with them
Steve A W
transom saver.
Post by Steve A W » 01 Aug 2016, 22:45
I use one because it gives the lower unit more
ground clearance.
I hit a deer one morning and the motor was the only thing
that didn't hit the deer!
I run 18hp down to 3hp and the transom saver fit them
differently. Just figure out where it rides the best.
Steve A W
Professionals build the Titanic.
Amateurs built the Ark!
lovedr79
transom saver.
Post by lovedr79 » 02 Aug 2016, 13:02
below.
