Building New Bunks - What 2x4 to use
Trailer related issues and discussion goes here.
Fishon72
Post by Fishon72 »
I’m in the process of rebuilding a PWC trailer to accommodate my 12’ duranautic. I’m putting on some new bunks with vinyl bunk wrap I got from Amazon. I know pressure treated and aluminum boats don’t mix, but is it ok to use under the vinyl? The other option would be normal 2x4 with some type of finish applied prior to installing the vinyl. What does everyone recommend for wood type and finish?
Thanks!
-Jay
DaleH
6
Post by DaleH »
I'd go with PT wood with vinyl gutter coverings ... simple, done, works - easy-peasy!
JL8Jeff
Post by JL8Jeff »
I wouldn't go with pressure treated, it can react with the trailer metal if it drips on it. The wood needs to air dry so even coating them with a sealer will actually trap moisture inside which will rot it out faster. We stained my cousin's dock a couple of years ago and those planks rotted out so much faster because it actually trapped the moisture. We'll never do that again. I went with plain old 2x4's with vinyl gutters cut in half when I redid mine a couple of years ago. I know you said you have the bunk wrap and that works fine as well, it's not as thick as the gutters though.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
mercracing84
1
Re: Building New Bunks - What 2x4 to use
Post by mercracing84 »
Could you use the plastic composite 2x4s?
LDUBS
5
Post by LDUBS »
If you want the best practice, this isn't it. If it were me, I would buy cheap fir 2x4's. Cover them with exterior carpet, vinyl or whatever and call it done. Just plan on doing it again in a couple years.
Have Rod - Will Fish
