electrical... a little showing off
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
captdan
Post by captdan »
As some of you know, I am currently attending a vo tech for marine mechanics. Electrical was not my strong suit going into the class, but now I can say I am comfortable with anything and everything electrical (at least DC wise).
I wanted to show a before and after pics of a boat I completed....I was a little perturbed seeing that this boat was actually ran like this.... could have caused a fire in less than a count of 1 had the free floating positives touched a ground.....
Here goes. this is what i started with:
after making a custom aluminum panel to incorporate an additional guage and a few more switches/breakers, the end result:
Tight Lines and Screaming Drags
15 Ft SEA NYMPH/ Merc 2 stroke 25 hp
16 ft Baycraft flats boat/75 yami
151 backcountry pro 60 merc efi
TOWBOAT US captain and marine mechanic
fish devil
Post by fish devil »
:twisted: WOW, what a difference. Nice work. Should be way easier to troubleshoot if a problem ever occurs.
Johny25
Post by Johny25 »
Nice job =D>
BOATS:
2002 Lowe 1467t
1988 Bluefin Sportsman 1900
1989 Spectrum 1900
MOTORS:
69' 6 hp Evinrude
71' 6 hp Johnson
85' 90 hp Evinrude
87' 9.9 hp Johnson (modified to 15hp)
88' 25 hp Johnson (modified to 30hp)
93' 120 hp Johnson
Gramps50
Post by Gramps50 »
Same boat :D
As you know you started with a real mess, The completed job looks real professional, great job.
--- Gramps
1985 1651 Polar Kraft 20 hp Mercury
HB 597 ci HD DI
Dragonman
Post by Dragonman »
That looked rough, nice way to simplify and organize. I would say you are getting you moneys worth at school. =D> =D> =D>
Bob Landry
Post by Bob Landry »
Very nice work. Having been in the marine business for 15 years, I've run into a lot of atrocities like that. It's usually a result of an owner adding or replacing equipment with no qualifications to do the job. You'll run into a lot of interesting situations such as hanging wire ends, wire sized incorrectly for the application, and some of the most interesting being different colors of wire, spliced together because that's what Gilliedgan had in his junk box. makes it fun tacing down a problem. Too bad most people don't know what tie-wraps are. They're cheap and they really make the job loook finished.
I picked up a G3 CC a few months ago that had alligator clips on the bilge and bait pump because the boat had sat outside and all of the electrical had corroded and stopped working. It was a salt water boat so that added to the problems. The solution was to rewire the entire boat.
captdan
Post by captdan »
thank you guys for the kind words. I was in shock when I saw the positive wires hanging . the owner had removed some breakers to add more switches for the courtesy lights be installed. thank you use household single core copper wire... definitely not the best thing for a marine application. I am glad we got to do the job before the boat burn to the water line. overall I was pleased with the job, and the owner was too...
Post by Captain Ahab »
Dude - that is soem nice work
I love how people do not even bother to use heat shrink fittings - crimp and let 'er fly, what could go wrong?!
lovedr79
Post by lovedr79 »
looks great!
RivRunR
Post by RivRunR »
Wow! Bet that was fun to untangle!
Very nice work there.
2000 Lowe 1752 VPT / Suzuki 60 4 stroke
HBird 898c SI / Helix 5 DI / Terrova 55 US2 iPilot Link
4 Metric Tons of Tackle
bgeddes
Post by bgeddes »
Nice work. You gave the owner a drawing right?
BOB350RX
Post by BOB350RX »
NOTHING LIKE A NICE A TIGHT ELEC COMPARTMENT, VERY NICE WORK, I HATE SLOPPY WORK JUST DOSENT CUT IT FOR ME
THIS THING USED TO FLOAT
https://www.tinboats.net/forum/viewtopic ... 21&t=20263, my 82 mirro build
https://www.powerstream.com/wire_size.htm voltage drop, and wire size charts, pretty useful stuff!! not just for 12v either
captdan
Post by captdan »
i am amazed at how many people try to rig their own things but dont realize the danger they are putting their ppassangers and themselves in. this os def not the first nor last cluster or birdsnest ill run imto... problem is in real world labor prices, the average guy wouldnt want to shell out the money. just in wires, butt connectors and female disconnects, he had over 200 bucks. add that to the time and it would have been a very expensive job. lucky for him we dont make any profit at the school.... he just paid for parts. he was nice enough to give us some money for pizza
Dman23
Post by Dman23 »
Holy nice work. That is a heck of a lot of wires. Im glad my electrical system is Much more simple! But if it was like that, id want it how you did it!
Regards,
Dustin
My Alumacraft 14' mod:
https://www.tinboats.net/forum/viewtopic ... 21&t=24959
