First post and first boat
Bought a 2011 1548 mod v hull lowe roughneck. Bare boat with a 25hp merc outboard. It has no outlets for lights, nothing, except one access point in the bow
I have drawn up a wiring diagram and would like the opinion of the forum on if it will work or not
I plan, currently, to only have a cranking battery and one deep cycle battery since many times there will be 3 adults and possibly deer in the boat and want to avoid any weight issues
The way I understand is that I can run the trolling motor off a positive bus bar with a 50amp inline fuse or breaker I need to add a switch or master between the battery and the fuse panel
here is what I've come up with
and here is the boat
loving it so far
loving it so far
