It is currently 25 Apr 2019, 06:19
mud-skipper
 Page 1 of 1 [ 6 posts ]
 Post subject: Newbie Preparing to work
PostPosted: 05 Sep 2016, 16:02
Hello all,
I currently have a 14 ft deep v hull with a 9.9 Mercury. I will be putting the following in my boat and need help knowing what I need and how many batteries.
1. 1000 gph Bilge Pump
2. Minn Kota Trolling Motor
3. Phone charging outlet
4. Navigation light on both bow and stern
5. AM/FM radio
6. Marine ship to shore radio
7. Compass
8. Lights inside of boat LED
9. Fish Finder
I plan on using switches to operate most of these electronics. What would I need in order to do that? What's a good switch can board? I am just really confused on the electrical side of things whereas the construction part of the boat is easy for me. I sincerely appreciate all the responses.
Thanks,
Robert
PostPosted: 15 Sep 2016, 17:21
I would go with 3 31M Marine deep cycle Batteries too start
PostPosted: 16 Sep 2016, 09:52
I think first off, you need to list specifics of your trolling motor....12V or 24V, and thrust. Also, is your motor electric start?
http://www.tinboats.net/forum/viewtopic.php?f=21&t=40764
PostPosted: 16 Sep 2016, 16:55
I'd go with 1 large deep cycle for lights, radio, etc. 1(or 2) for the trolling motor, then a separate small motorcycle battery for starting(if electric start)
Eat, drink, and be merry, for tomorrow we die
PostPosted: 16 Sep 2016, 17:16
That is a long list for a 14-foot boat.
But, your boat, your money, your choice.
I have a 1652 G3 with an electric start; tilt/trim 50 hp motor and a 55 lb thrust MinnKota trolling motor. I have a 650 ( I think) bilge pump; a phone charger; nav lights; Fish Finder; and lights inside of the boat. I also have a live-bait/well. Two pumps, one to aerate and one to pump water in and out.
I get away just fine with only two batteries. One regular starter and one deep cycle.
I do not run the trolling motor all day as I arrange to simply drift my shorelines a lot. I use two drift chutes/anchor chutes to slow her down.
Before you start buying batteries, you might want to accurately measure the space available for whatever you wind up with. It doesn't matter one bit what someone thinks you should have .....if you can't fit it into your craft.
Also, batteries are the d@#$% heaviest things that we haul around. Placement of those batteries and the wiring necessary to get them to do their jobs properly are a constant conversation on this site. Too much weight in the stern ( constant complaint) will screw up your ability to plane.
I don't have items 5 through 7. I suspect that the compass would draw very little current. Would you be running the two radios all of the time ....or are they only drawing current when used sporadically?
Tell us more.... regards, richg99
5. AM/FM radio
7. Compass
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
PostPosted: 21 Sep 2016, 11:25
Minus the AM/FM radio, I have all that on my 14' StarCraft. I think my bilge is 500gph or thereabouts. My motor is electric start, no tilt/trim. Anyway, I run it all with a single, group 29 deep cycle battery.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
Users browsing this forum: Google [Bot] and 17 guests
SwampRunner
