Need some advice about where to mount my onboard charger
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
Creedmoor
Post by Creedmoor » 11 Sep 2016, 18:48
Hoping to get some help with deciding where to mount my onboard charger.
I got tired of moving my one charger around so I purchased a two bank onboard charger but now I can't decide where to mount it.
My boat is a G3 1860 with a center console.
There just isn't space in the console so it will have to be mounted in the stern near the starting battery.
If I mount it inside the battery compartment, It will be really close to the fuel tank but it will be more protected from exposure.
If I mount it outside the compartment, it will have to go on the transom and will be more exposed but it says it is 100% water proof.
The instructions say to not mount it directly to the aluminum surface so I will be mounting it on a piece of wood that will me mounted to the hull.
Here are some pictures.
I would appreciate any advice or input.
Rear storage compartment with lid closed
Door open with charger positioned where it would go. Note fuel tank in the bottom of the photo.
The only other spot that it will go is on the transom.
You can see that transom is pretty high and would protect it somewhat from waves or splash over. It's waterproof anyway.
RiverBottomOutdoors
Post by RiverBottomOutdoors » 11 Sep 2016, 19:20
Do you have the fiber glass or aluminum G3 console? I have a G3 1556 CCJ with alum console and have a good sized 3 bank charger mounted under it.
Creedmoor
Post by Creedmoor » 11 Sep 2016, 19:24
RiverBottomOutdoors wrote:Do you have the fiber glass or aluminum G3 console? I have a G3 1556 CCJ with alum console and have a good sized 3 bank charger mounted under it.
It is fiberglass and there is almost no space in there. I can't see anyway to get the charger in there.
jbird68
Re: Need some advice about where to mount my onboard charger
Post by jbird68 » 11 Sep 2016, 21:00
I had my ProSport 12 mounted on the aluminum sidewall of my old boat for years. Never had any problems. Image
Sincerely,
jbird68
2006 Alumacraft Navigator 165 CS (Crappie Slayer)
2006 Mercury 90 HP Optimax
1979 Evinrude 6 HP Long Shaft Kicker (To be installed)
Minn-Kota Terrova 24V 80# Thrust Trolling Motor w/ I-pilot
2006 Dodge Durango SLT (Bright Blue) 4.7L Next Generation V8
Creedmoor
Post by Creedmoor » 11 Sep 2016, 21:03
jbird68 wrote:I had my ProSport 12 mounted on the aluminum sidewall of my old boat for years. Never had any problems.
Sincerely,
jbird68
Thanks for that info.
I'm not sure why they recommended not doing that.
jbird68
Post by jbird68 » 11 Sep 2016, 21:05
I don't know. But mine is about 15 years old. Maybe they changed something in the new models.
Sincerely,
jbird68
jbird68
Post by jbird68 » 11 Sep 2016, 21:06
Maybe instead of using a board, if you decide to do that, you could use some rubber washers if you don't want it directly on the panel.
Sincerely,
jbird68
Creedmoor
Post by Creedmoor » 11 Sep 2016, 21:29
jbird68 wrote:Maybe instead of using a board, if you decide to do that, you could use some rubber washers if you don't want it directly on the panel.
Sincerely,
jbird68
I've got some 1/4" rubber backing left over from another project, that might just work.
Thanks
