Fuse size
What size wire are you running to it and how long is the run? Does the 12-V outlet have an amp rating? What do you plan to use it for?
Of hand, I'd probably use a 15-amp fuse, but that would depend on the answers to the above questions. That assumes a relatively short run with 14-ga wire and that the outlet you have is rated for that current (I would suspect it is rated for at least that).
Thank you for the reply. the outlet came in a generic box and didn't list the amps. I ran about 9 foot of 12 gauge wire
