What kind of circuit breaker
Rsb1970
I need a 50 amp circuit breaker for my minn-Kota 40 lb thrust trolling motor. Minn-Kota brand is around $35. I’ve seen some for anywhere around $10 to $50. Does it matter what kind I get ? Thanks
I got my circuit breaker and I know how to hook everything up. But where do I mount the breaker at. Do I just let it sit on top of battery? My battery is in a battery box sitting on the floor.
Doesn't really matter where you put it, just as long as it's as close to the battery as possible.
Bussman get'em cheaper from Amazon, this is how I have mine connected to the battery. I used a piece of copper 1/2" pipe smashed it flat in my vice drilled the holes and shaped with my grinder.
