Fish finder battery mount?
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
bikerider
1
Post by bikerider »
I just bought a battery exclusively for the fish finder in my boat and am curious where others with this setup have mounted it? The fish finder battery is about 6" long, 4.5" tall and 2.5" wide.
12 ft Starcraft
Setup on a budget for fishing
:fishing:
1960 yellowboat
Post by 1960 yellowboat »
I have the same kind of battery for mine. I put it in a plastic ammo can that I got from Harbor Freight. Put some styrofoam padding in it for a snug fit and connected a quick disconnect wire fitting to it.
bikerider
1
Post by bikerider »
1960 yellowboat wrote:
18 Dec 2019, 17:11
That's a good idea using an ammo can. Nice and secure too. Do you happen to have a picture?
12 ft Starcraft
:fishing:
gnappi
2
Post by gnappi »
bikerider wrote:
18 Dec 2019, 19:58
18 Dec 2019, 17:11
If I were you, I'd make sure the "ammo can" is not metal, if it flips over and it's steel... not good. There are plastic models available.
Regards,
Gary (in South Florida)
bikerider
1
Post by bikerider »
Anybody else have ideas for mounting the small fish finder battery? I thought about putting it in front of the trolling motor battery but was hoping to leave as much floor space open as possible. I wanted to mount it laying on it's side underneath my swivel seat next to the base but it's a bit too tall.
12 ft Starcraft
:fishing:
moecarama
5
Post by moecarama »
I connected mine with a SAE connector for a quick disconnect to a 18ah-12v battery. It was installed in a small utility battery box but has since been moved to the storage box beneath my seat along with a small 4 gang blade fuse holder (additional accessories) :D It might be visible in the pics attached.
2010 12ft.Topper Jon 5hp Mercury
1989 Alumacraft 16ft. 45hp Mercury 50Classic
2002 Bass Tracker PT185 90hp Mercury
bikerider
1
Post by bikerider »
I like that setup ^ Thank you for the pictures.
12 ft Starcraft
:fishing:
bcbouy
Post by bcbouy »
old boat,but i mounted mine to a piece of carpeted plywood with a seat mount so i could move it around where i needed.the battery is held down with a strap.
if all else fails....stop using all else
bikerider
1
Post by bikerider »
bcbouy wrote:
12 Jan 2020, 17:42
That's pretty smart. It seems like you are always moving around the boat while out fishing. I like the portability of your old setup.
12 ft Starcraft
:fishing:
Riverdog
5
Post by Riverdog »
I've ordered from these guys before. good stuff, just a little pricey.
https://www.fishfindermounts.com/produc ... -5-screens
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
bikerider
1
Post by bikerider »
Riverdog wrote:
15 Jan 2020, 19:08
That's a nice compact setup. I ran across that company when I first installed my fish finder.
12 ft Starcraft
:fishing:
1960 yellowboat
Here's my little rig. It's a PLASTIC ammo box,$3 at HF. A 8AH sealed battery in it with styrofoam padding to keep it secure. The battery is leakproof and so is the ammo can, And it floats!
bikerider
1
Post by bikerider »
That's clever to use styrofoam in the box so it floats. Do you just open the box when you want to connect the fish finder?
12 ft Starcraft
:fishing:
1960 yellowboat
Although you can't see it in the pictures, I drilled a hole in the top for fish finder and battery leads. Lots of silicone sealant around the hole
bikerider
1
Post by bikerider »
17 Jan 2020, 17:41
That's a good call. You don't want water getting in there.
12 ft Starcraft
:fishing:
