What you'll need:
$0.10 - Blade
$0.05 - Snap (20#)
$0.07 - Split Ring (20#)
$0.12 - Mustad #32608N Size 4/0 (not the hook pictured, but probably the preferred general public chatterbait hook. Pictured is a 3/0 EWG Mustad Flat Eye jig hook.)
$0.40 - 1/2oz Casting Sinker (can easily swap sizes up or down - its connected only to the split ring.)
$0.35 - Jig Skirt
$1.09 TOTAL
I believe I bought the blades and jig hooks from Lurepartsonline.com, but really any build-your-own website will carry them. I paid $1 for 10 blades. - snaps, split rings & casting sinkers can be found just about anywhere.
Purchased in any reasonable bulk the individual parts total ~ $1 including the cost of a skirt (I make my own, so each costs ~$0.35 - but you could purchase a 4 pack at Walmart for a few bucks.)
Should be pretty self explanatory - connect the snap clip to the blade, attach the split ring to the bottom of the blade, attach the casting sinker to the split ring...the only part that takes any time is whipping on 4 strands of a plastic jig skirt to make the hook keepers. Not being fancy, I used some scrap superline that was at the bottom of the spool that wouldn't fit on my reel, but any braided line will work. Secure the knot in the line to the shank of the hook using a dab of superglue starting at the end farthest from the eye of the hook & working your way back toward the eye. Peel off the skirt strands in pairs, bend them way back so they stand out as you'll need them to block your skirt from sliding backwards or from having your soft plastic trailer slip off. I've found these keepers actually work better than the barbed ones on most jig hooks, and if I'm fishing a soft plastic without a skirt I will add these to be sure it stays in place.
IMPORTANT - use hooks with a "flat eye" or your hook won't track correctly.
Final assembled setup looks like this - NOTE - observe the positioning of the snap on the blade (on the opposite side from the hook). Also you tie your line to the backside of the snap (typically connected to the swivel in a swivel-clip setup.) It looked a little wierd the first couple times I did it:
I added a quick change clip to the split ring & attached the casting sinker to this instead so I can swap the weights around & get the drop rate just right.
And lastly with the skirt attached & the ribbon tail from a chewed up worm donated to be used as a trailer. I trim the skirt to be just longer than the hook on these smaller chatterbaits:
With the weight dangling beneath the hook these are very weedless - you should feel the top of the weeds with the weight before your hook is buried in them. Furthermore they come over brush very well, as the weight deflects off obstacles while the hook is riding 1/2" higher up and can't roll to the side. It is not a texas rig, throw it into brush and it will hang up.
