New bearings/seals kit and water pump kit questions
Whitaker201
Ohio
I am going to replace the bearings in my jet pump and the impeller for the cooling system. Is there any tricks or any problems that I need to watch out for? I know to install the bearings I am going to need to have access to a press and I am trying to get that lined up still. I have a model L pump.
Been a while since I've had mine apart but think there's a certain way the bearing needs to go on, heard they don't last but a couple minutes if they go on backwards. Just take your time and make sure where everything goes, pretty simple swap.
I chicken'd out after I pulled the shaft out since I didn't have access to a press. So I dropped it off at lunch to get the bearings/seals replaced at the local boat shop and picking it up this evening. Now I just have to put it back together.
The way the impeller pulls the shaft downward the bearing has to go in where the open part where you can see the balls is facing up. If you put it in backward the thrust will physically pull the bearing apart.
