It is currently 18 Apr 2019, 17:13
SwampRunner
 Page 1 of 1 [ 6 posts ]
PostPosted: 11 Oct 2016, 10:33
Hi guys, long time lurker, however, this is my first post.
My grandfather's jet has a major crack in the outside casing of the lower unit. Its crazy, the thing is still hanging on there as it wiggles left and right when shaken.
The motor is 1996 4 cylinder Mercury 2stroke jet 40/30. I looked for a replacement part and I am seeing prices around $500-600... I believe this is a universal part for all 40hp short shaft Mercury motors. Does anyone have a parts motor lying around? Or any ideas where I could find a used part?
thanks guys,
-Greg
PostPosted: 11 Oct 2016, 12:33
Ebay or Craigslist are always a good place to start.
PostPosted: 11 Oct 2016, 13:27
I think I would try to have it welded first and go from there. Running it the way it is will probably only do more damage.
PostPosted: 12 Oct 2016, 08:27
I just bought a 97 40/30 Mercury with low compression in 1 cylinder (mainly bought it for the hull).
Everything else looks intact. If your interested send me a PM and I'll send pics.
PostPosted: 12 Oct 2016, 10:49
rktman, thanks for the reply. I just found one on ebay [url]http://www.ebay.com/itm/302089380958?euid=92af864c98af4ac6a2a3b12718a90336&bu=44389750995&cp=1&sojTags=bu=bu/url] I will see if this one works. However, I may be interested in some of the other working bits from your motor. The reverse linkage at the outdrive is very clunky to use. Lots of forces and jiggling is required to go from F to R sometimes. Can you take a picture of yours?
PostPosted: 12 Oct 2016, 21:33
Here's the one I have.
Users browsing this forum: No registered users and 25 guests
