Transom Outboard Jet Spray Deflectors
jtf
Northwest NC
Would members direct me to posts, or post some pictures of outboard jet transom spray deflectors? Had one installed and I think it is going to need some more work.
If the name isn't right, a box or plate above the jet foot to deflect spray.
Thanks
Pix of the one I have on my boat. Had to put an extra fold in it in order to clear the live well intake screen. It's better to have a straight plate if possible, but this one works well. The plate is made from a 12" x 12" square of 1/8" aluminum diamond plate. Mostly because I already had it. A 1/16" thick aluminum plate would probably be just as good and would also be easier to make the necessary folds. A good spray plate will also help to reduce cavitation as well as reduce spray. The Schnauzer is Henry. :D
Thanks Larry, I had seen some pics of a deflector like a bill cap with ear flaps and didn't know if the flat plate was going to be enough. Will have to weld gussets in a couple places on top for bracing.
Found a post of yours showing another boat that had a thicker piece of metal with UHMW on the bottom.
Here is mine, original one is at the top. The bottom one I made out of .125 aluminum plate.
Most spray happens when water goes over the lip of the shoe. It follows the u shape bend on the pump and shoots back to the transom.
dhogan, mine is like your 1st one. Maybe get better results with ones like you guys. The boat is still a work in progress.
