my idea for a jet jon build will it work?
amk
6
Post by amk »
That number for dan I called and it says it doesn't except incoming calls or something
PSG-1
Post by PSG-1 »
Hmmm, that's odd. But then again, he just re-located his shop a month ago, so, that might have something to do with it.
Try his cell (843) 450-9101. I'm pretty sure that number works.
ALUMA-JET project:
https://www.tinboats.net/forum/viewtopic ... 21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy.
Watch it all right here:
https://www.youtube.com/user/HKPSG1Shooter?feature=mhee
amk
6
Post by amk »
I see alot of guys putting little v shapped wedges before the grate on the bottom is that necessary?
He Reigns
6
Post by He Reigns »
Mine is a rounded V. Technically it should be shaped like a spoon, hence its name, "spoon".
amk
6
Post by amk »
yes but is it necessary
He Reigns
6
Post by He Reigns »
amk wrote:yes but is it necessary
Um, well, that it a hard question to answer. Most of the successful builds I have seen have them. Some try without and depending on hull design it may or may not work, then add it as needed. I built mine while doing the install to avoid grafting it on later.
Necessary? With so many different boat hulls and jet ski pumps being used I believe every install is different, some may benefit from one, some may not.
amk
6
Post by amk »
one of the cylinders isnt holding compression anyone got a 650 short block? :cry:
amk
6
Post by amk »
Got the motor rebuilt and found a guy to build the boat since
amk
6
Post by amk »
Coming together nicely
PSG-1
Post by PSG-1 »
Very nice work on that tunnel modification! Looking good.
ALUMA-JET project:
amk
6
Post by amk »
Transom tacked on
amk
6
Post by amk »
Sponsons on next is housing and console
Nlawson0017
6
Post by Nlawson0017 »
Thats some good looking fab work. =D> This build is coming along nice.
-Nate
1648 Polarkraft 60/40 Jet
24 ft flatbottom project
smackdaddy53
Post by smackdaddy53 »
That is kick ass bro. Really nice fab work!
~Mac~
amk
6
Post by amk »
Motor mounted and pump sealed
