Trim nozzles and trim tabs
Bx10
Post by Bx10 » 12 Sep 2016, 20:28
I got spoon built and tested it out I went heavy cavitation not being able to over 5mph to now I got it up to 35mph but I am it's statting to bounce bad after anything more than 20mph I have tryed may trim nozzle each way plus are they supposed to case spray back I'm getting alot spray back into my boat. I was also wondering what's a good starting length on a trim tab
Post by richg99 » 16 Sep 2016, 17:46
I know ZERO about jets. I know a little about Smart Tabs. (Trim tabs) if that is what you are asking about.
I guess if I were going to build my own ( I won't)...I'd just look at their website and take down the suggested sizes for various boats and horsepowers.
When I bought my first pair, I screwed up on the size of the gas struts. They (Nauticus)... the manufacturer swapped them out for me at no cost.
http://nauticusinc.com/smart-tabs-sx/
CedarRiverScooter
Post by CedarRiverScooter » 16 Sep 2016, 18:12
You could try some weight up front to cut down on the porposing.
brianb2247
Post by brianb2247 » 16 Sep 2016, 19:53
on jet skis they have ride plates engineered at the precise degree that provides lift to the back of the boat to eliminate porposing youll have to design one i had the same issue so dont get discouraged,there are alot of guys on here who come up with different solutions that work well almost every time , i have pictures of my on my rhino jet build post if you need any more info just contact me, hope my pics help
Bx10
Post by Bx10 » 17 Sep 2016, 13:33
So pics of the layout of my boat I have the ride plate on it I'm not sure that it's on the right angle cause that a differnt nozzle the motor is 3 cylinder 1000 tigershark motor besides that just the gas tank and a battery in the back
Bx10
Post by Bx10 » 17 Sep 2016, 13:39
I was going to build a seat n live well onto my center consle think that passenger weight would balance it out. I want to put the gas tank and battery up fornt but my whole front deck it sub framed in with foam pods so I be a pain to cut it open
Bx10
Post by Bx10 » 17 Sep 2016, 14:03
If I cant get it the thing right I was going to down size the motor thinking about getting a seadoo n actually putting part of the hull in it so everything is right. I made everything out of aluminum on mine boat. 1/4 throttle almost 30mph Im so close to getting it right I wanna know how it will go. I want to whole build thread on my boat sence it's my frist time and not know if it even work I was going to wait intill I had it right. I dI'd want to point other in the wrong way
