thoughts on stomp grates?
Capt1972
5
Post by Capt1972 »
Do they clear weeds? Is it worth fabricating one for a jet-jon?
Proceed.
PSG-1
Post by PSG-1 »
Yes, they clear weeds, for sure. And considering what a PITA it will be to clear weeds without one, it's well worth the effort to make one.
Check out page 1 of my aluma-jet build. Toward the bottom you will see some pics showing how I built my stomp grate.
You can make the tines out of 3/4" x 1/4" stainless flat bar. That's better than the brittle cast aluminum ones that are typically found on intake grates. You won't break stainless, no matter what you hit.
To make the tines, cut them a little bit longer than the intake opening, long enough for the back end to overlap the lead edge of your intake plate. Use a grinder, and grind a 'step' on the end of each one. This will allow them to fold up against the intake plate edge, and keeps them from being able to flip up into the intake if you bump across a log, rock, etc.
For best water flow dynamics, sharpen the bottom edge of the tines like a knife edge, and on the top edge, grind to a radius. A belt grinder makes quick work of this. If you don't have one, use an angle grinder with a coarse flap wheel, it will do a nice job of removing material quickly without overheating and pulling the temper from the material.
Next, cross drill through the tines on the forward end for a bolt which will act as your pivot. Drill another hole through all of them, a few inches back from where you drilled the other holes. Through here, use another bolt, with a nut on each side of each tine. This will lock them all together, and keep them correctly spaced.
Then, where the front end of your intake grate bolts to the pump intake, you will need to modify this block of aluminum by having a set of lugs welded on each side, and one in the center. Cross drill these lugs for your pivot bolt.
Next you'll need a tele flex cc633 series push-pull cable, with 4" of travel. You'll also need the other items shown in page 1 of my build, such as the rubber grommet, and locking collars, and the 3/4" NPT cap with a center hole drilled for the cable to pass through.
Hope this info helps! The pics of the grate on my build is the older configuration. It doesn't have the step cut into the tines. I can take pics of my newer, improved grate... let me know.
ALUMA-JET project:
https://www.tinboats.net/forum/viewtopi ... 21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy.
Watch it all right here:
https://www.youtube.com/user/HKPSG1Shooter?feature=mhee
ColtonS
5
Post by ColtonS »
No offense PSG.... although yours is a great concept its more of a weedless/wash system rather than a stomp grate. A stomp grate will have 2 sets of bars, one set that hinges and one that does not. When every other bar hinges it allows for the removal of rocks and debris that are stuck between the grates.
PSG-1
Post by PSG-1 »
No offense taken. Thanks for correcting me on that.
I was under the impression that stomp grates and weedless grates were the same thing, but it makes perfect sense to have the pivoting and fixed bars in an alternating pattern for un-jamming rocks stuck between them.
Indeed, mine is a weedless grate, as it's a direct copy of the one sea doo uses on their jet boats, and theirs is listed as a 'weedless grate' I'm usually operating where it's mud and sand, but occasionally, there's a risk of picking up an oyster shell. And every once in a while I like to go to inland rivers where there may be gravel.
Now I'm wondering if I should re-re-design my intake grate to be more like a stomp grate, and if I did..... would it still work for clearing weeds. :?:
ALUMA-JET project:
Ranchero50
Post by Ranchero50 »
When I suck up weeds they are wrapped around the back (or bottom) edge of the intake grate and I can pop them loose with my hand from behind the boat (without getting in the water). I'd thought about a stromp grate but think a cheap steak knife blade screwed to the back of the grate would work better to cut the blades of grass in half.
