handyandy
Well I'm more of a omc man most of my engines in the past have been omc and I've had good luck with them. But I'm not completely biased I'm wanting to switch my boat to jet which led me to buying a mercury mariner. Currently I run a 40hp 3cyl carbed nissan tiller short shaft with a prop it came with the boat and has been good and a atlas micro jacker jack plate it works. But a jet would be best for most of my use fishing/hunting shallow rivers. The 40 with the prop is about perfect for power on my hull not crazy fast or powerful but enough to go well and plane out fine with a 2-3 guys and fishing or hunting gear. I figured if I switched the 40hp to a jet foot it would probably be under powered and struggle to plane. So I found a 94 mariner 60hp tiller short shaft for a ok price not far away had to drive for it but larger tiller outboards are somewhat hard to find especially short shaft which is nice so I don't have to modify my transom. Figure the 60 with a jet will probably be close to my 40 with a prop as far as performance.
My problem now is I figured that mariner wouldn't be to hard to find a pump for since the 60hp mercury/mariner power head was common. But I'm not having any luck finding a outboard jet lower for it despite it being a pretty common and large produced jet pump. I'm trying to avoid huge price tag of a new outboard jet. I'm looking for ag model outboard jet, so if there is anyone with one, or you know of one, or any place that might have one I would greatly appreciate it. Long time reader of this forum first time poster I've appreciated all the info I have gotten from this forum so far so I'm really hoping someone might be able to help.
