Reverse gate adjustment
buckmaster27012
Post by buckmaster27012 » 12 Jul 2016, 20:45
sometimes when i have boat going forward and then try to shift it back to neutral it gets a little hard. almost have to force it back. i have loosened up the bolts as much as i can to get give it some play and its always goes smooth after this in the yard but when i have it in the water its hard. i've run out of ideas, any got any suggestions? thanks
MrTotty
Post by MrTotty » 12 Jul 2016, 22:34
How old are your cables? Got them in a tight bend? My brand new rig was super hard to shift, I had to cut a few zip ties to allow the cable some freedom. You can also try a little lube on the roller, but it's not going to last very long.
RiverBottomOutdoors
Post by RiverBottomOutdoors » 13 Jul 2016, 10:11
Check the roller on the gate cam and the cam itself. Roller should spin freely. Track of cam should not have any hangs in it.
buckmaster27012
Post by buckmaster27012 » 14 Jul 2016, 07:18
cables are the original that came on the boat, its an 01. they move freely though when in the yard checking it out and making an adjustment. the rollers is almost brand new because lost the roller and bolt one night running up river. took a bit to figure out why boat wouldnt stop going forward. i'll keep messing with it and see what i can come up with.
RiverBottomOutdoors
Post by RiverBottomOutdoors » 14 Jul 2016, 09:14
Doesn't matter if the roller is brand new. Whomever assembled it could have over tighten it so that it doesn't spin freely.
JL8Jeff
Post by JL8Jeff » 14 Jul 2016, 10:28
How's your idle speed? If it's too high it could be pumping too much water through making it tough to move the gate. Is there any buildup inside the reverse gate? Corrosion or marine buildup will make the water grab it more so it's difficult to move.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
1993 Jetcraft 13' sprint boat with Chevy ZZ3 350 engine and Hamilton 772 jet drive
