Splash / Spray Plates
redrum
Post by redrum » 05 Aug 2016, 20:05
Can you guys post up pics of how have your spray plates mounted. I used a bend piece of aluminum on my old boats. I'm working on putting one on my Grizzly and just trying to see how others have done it. No tunnel, so I can't bolt it to the top of it. I'm gonna have to bend up something I guess.
1648 Tracker Grizzly Mercury 60/45 Jet
1648 MonArk 50/35 Evinrude Jet
1444 Polarkraft 50/35 Evinrude Jet (Stick Steer)
buckmaster27012
Post by buckmaster27012 » 06 Aug 2016, 07:13
dont have a pic but on my previous boat with no tunnel i just trimmed motor all the way down then got a piece of aluminum and bent it about 2 in piece of it up and then put up against the back of boat and got the angle on it where it was barely not touching the top of the jet foot. couple of self tapping screws and silicon and was good to go.
kgrant
Re: Splash / Spray Plates
Post by kgrant » 08 Aug 2016, 05:27
Here's my setup, 1648 lowe flat bottom.
dhoganjr
Post by dhoganjr » 08 Aug 2016, 06:07
This is the best pic I have of mine. I cut a round shape in it to match the pump so it would extend out farther around the sides and not hit when trimmed all the way down. Also had to bend the ends down to keep it from hitting. There is also another one you can barely make out at the top of the pic that the builder installed, it is about the bottom of the pump and is shorter.
I still had spray with the original one, so I made the new one and it cut down most of it.
Dan
2003 1860 Alweld Flat Bottom
2014 Mercury 250 Pro XS Jet
2003 RiverCraft trailer
Retired from Riverlife-2002 Mercury 115 Fourstroke Jet
Sully
Post by Sully » 09 Aug 2016, 18:30
dhoganjr wrote:This is the best pic I have of mine. I cut a round shape in it to match the pump so it would extend out farther around the sides and not hit when trimmed all the way down. Also had to bend the ends down to keep it from hitting. There is also another one you can barely make out at the top of the pic that the builder installed, it is about the bottom of the pump and is shorter.
Dan, do you have any measurements for your plate? I need to make a longer one too.
Mike
MIke
2015 Alweld 18/56jc
2014 Mercury 250 Pro XS jet
2015 Rivercraft trailer
dhoganjr
Post by dhoganjr » 10 Aug 2016, 13:18
I will try to get them after I get home Friday. I bought a piece of scrap at Spacewalker's in Bonne Terre. I had them bend it there and I cut it to fit. I think it is .125
Dan
redrum
Post by redrum » 10 Aug 2016, 15:59
I've always used old road sign material to make mine. I think its .080 aluminum. It doesn't bend all that well. It sort of tears at the bend when you go beyond 90 degrees.
The grizzly is a mod-v bottom so I have a plug hole to deal with and I have to raise the plate up just a bit. Sort of like in this picture.
I've never put one on or seen one on a mod-v before that didn't have a tunnel.
blkhoe
Post by blkhoe » 18 Aug 2016, 21:19
Had to make a longer one after adding the cmc unit.
Sent from my LGLS675 using Tapatalk
Downtown
Post by Downtown » 10 Sep 2016, 06:36
here is the one i had on my grizzly mounted it to my jackplate.
2011 GMC SIERRA
2014 Crestliner VT17 Pro Edition w/Mercury Optimax 115/80 Jet
