E-Tec tiller on OMC 3cyl.
Xterminator GT
Post by Xterminator GT »
[ external image ]
My latest project is putting an e-tec tiller handle on my 56” OMC. My reasons for swapping it over are trim switch in the end of the throttle, it’s longer, and the shifter is much easier to reach.
The tiller bolts up like it was made for it. The shift cable will hook right up like factory. Don’t mind the picture, mine is an outboard jet. I’m getting a longer shift cable made. Since my motor is a ‘99 all the wiring plugged in like factory. The throttle is where things get a little more complex. The etec throttle throw isn’t as long so you have to make a little bracket and do some adjusting on all the linkages, but overall it’s a very easy swap.
2009 Xterminator GT 1752
2009 Rivercraft trailer
1994 Evinrude 60/40 3 cylinder jet
Stumpalump
6
Post by Stumpalump »
Nice work!
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
eshaw
3
Post by eshaw »
That's pretty slick.
Xterminator GT
It’s a really easy swap. I haven’t gotten to run it yet. I’m waiting on a shift cable and a new water pump kit before I put my jet on. I’m excited about running it though.
eshaw
3
Post by eshaw »
Make any more progress?
Xterminator GT
I’ve got the motor all together and ready to go. My boat is at the shop getting the transom riser made. Hopefully be on the water next week. Since I done away with my console, this was the best place I could think of to put my tach. I wanted the biggest I could find. Luckily I found this 5” Autometer marine on sale. [ external image ]
eshaw
3
Post by eshaw »
If you don't mind my asking, where did you get the perforated sheet from and the pinch weld protector around the edge? I've been trying to locate those two items for a while now!
Xterminator GT
It was in the boat when I bought it. It’s a very popular set up here in MO. I’ll never have one without it again.
eshaw
3
Post by eshaw »
Thanks for the reply. I finally found some of the edge trim online. Now I just need to find the perforated sheet.
eshaw
3
Post by eshaw »
Thanks for the reply. I finally found some of the edge trim online. Now I just need to find the perforated sheet. What kind of boat is it?
Xterminator GT
17x48 Blazer SS
bdk_wa
2
Post by bdk_wa »
I have done this on a 1984 70hp johnson.
Here is a thread where I helped someone else.
https://www.ifish.net/board/showthread.php?p=8083178
This guy talks about it too...
https://www.leeroysramblings.com/conver ... tiller.htm
This is the piece that I modified to get the carbs to open and close the same amount with the shorter throw. The remote controller throttle cable traveled something like 2.75 inches and the tiller throttle cable traveled 1.5...those numbers are close. I marked the location of the carbs at idle, start, and wide open throttle (both where the carbs are and where the roller on the cam is. Then I started by removing the cam and tracing it on a piece of 1/4 plywood. and then reinstall OEM cam and I connected the tiller handle. and moved the throttle to all three marks. and measured the distance that I would have to add to the cam to get the carbs to the position in relation to the marks on handle for start and WOT and added that much material to the plywood template cam in those locations. Cut our the wood cam and test. If the roller travels smoothly on the cam and it puts the carbs in the correct positions then you are really to water test. I used washers and my plywood cam for first test. When happy with the performance create a aluminum version of your plywood cam. NOTE* you will notice the level that connects to the throttle cable all so advances timing don't worry too much about this as that timing carrier travels its full distance early in the movement of the throttle travel. I was careful to out change the relation of the time and position of the carb linkage until timing was fully advanced. I have run the motor for a year now and love it as a tiller. Probably been 6 years now...no issue. It made the boat MAY more fishable.
redrum
6
Post by redrum »
I'm amazed at the tiller jet boats out in MO. I want to go out there and check out these rivers. Center console boats are pretty much the norm here in Georgia / Tennessee. Are there many rocks? Are the river bottoms sand and mud?
1860 SeaArk MV Mercury 60/40 Jet
1648 Tracker Grizzly Mercury 60/45 Jet
1648 MonArk 50/35 Evinrude Jet
1444 Polarkraft 50/35 Evinrude Jet (Stick Steer)
Xterminator GT
Mostly gravel bottom with big rocks here and there. Nothing to challenging to navigate for the most part. The Current river is where I do most of my running, it’s pretty shallow.
Xterminator GT
I finally got the motor hung tonight. I’ll be ready for a test ride tomorrow.[ external image ]
