Cubman
The boat must be picked up in Oak Ridge, TN. I am not interested in any trades.
For sale is a 1998 Solid Craft 2070 tunnel hull, 1995 Johnson Fast Strike 115, and galvanized tandem trailer.
The boat is all 1/8" plate and has a prop tunnel. The bottom is 70" wide, the beam is 92", and the sides are 26" tall. It has front and rear decks, dual consoles, and two rod lockers. There are (4) 400w HPS lights on the front. The trolling motor is a 24v 80 lb Minn Kota, with 45 amp converters for each battery.
The motor has a new water pump and lower unit oil. It has been well maintained and runs well. It is mounted on a high speed hydraulic jack plate.
