Post a Pic of your...trailer?
Hey ya'll,
Glad to see that the "Post a Pic of your Trailer" thread is taking off. I've always had a weird fetish for trailers since I was a young lad (I attribute it to many cool HotWheels and MatchBox toys).
I also think it's a good place for all of us to see what cool mods that like-minded buddies have done to their boat haulers.
Kudos!
Kudos!
1970 Ouachita 12' v-hull, 64" beam, 50lb Minn Kota, 1965 6hp 'rude
Wise man say: "Buy the smallest boat you can be comfortable on, not the biggest boat you can afford."
Additionally: It doesn't matter how small your boat is...they ALL cost money! More money than my wife knows about...so SHHH!
Ringo, sorry for the late reply, I just noticed your post/question.Ringo Steele wrote:By the way...what size tires and wheels do you have? They look wide for their height.
The tires are 8" x 18.5". Basically they're just like golf cart tires with a much greater load capacity; 940lbs. I think they're a heck of a lot better than the skinny 8" Harbor Freight ones, but I would prefer a full-size car tire; 13"-16".
I think my trailer has enough room under the fenders for larger tires, but these are solid and I have other "boat projects". Maybe they'll get changed out when I restore/rebuild the trailer in a few years.
hahaa, heres mine, just brought it home! a continental jb-127 =D
This is the best one I have right now..
2004 load rite bandit galvanized.
Running 12 x 4.8 tires with bearing buddies
Less than 30 miles on this trailer!
2000 Procraft 190 SuperPro
2000 Mercury 175 EFI
Stock picture of my trailer from when I bought it...lol
Jeff
Jeff
I picked up this trailer late fall/early winter. The 13" tires had dry rot so I put new tires on it. The bunks need new covering and the winch mount (welded to the tongue) was too far back for my new boat project so I ground it off and welded it on farther forward. So I've got some work to do on it before the new paint, but I thought it was a pretty good deal for $60.
JMichael - Not a bad deal for $60, I definitely seen a lot of people do a lot worse for a lot more. It's good do get a solid trailer to start with and customize from there.
Any new pics of trailers out there?
Is there any way we can make this a "sticky" since the majority seems to want to see your trailer pics?
(And I don't have to keep shamelessly bumping it to keep in up top.)
Found the forum after I tore down the trailer. New guides out of 3/4 rigid conduit, will throw some PVC on it and mount my lights on top. Paint, New bunks and new Tongue. Tongue that was on it was bent and a bit short. This forum has saved me a couple of humbling phone calls to my Dad. Thanks
Trailer build in my signature. I completely rebuilt it 3 years ago.
HOI Crappie Club
Where family and friends come to compete for a little more than bragging rights.
'97 16' Sylvan Back Troller Select
'67 14' Alumacraft
'57 Model FD11 18-hp Johnson Seahorse
'09 Traverse FWD V6 w/ towing package, power sun and moon roof, and ton of other options. The only one I wanted was the towing package.
'67 14' Alumacraft
This is the trailer that came with my 12' northwood boat. Not sure of the year or make, but it gets the job done.
Had to add lights, new bunks, and a new winch. I will probably also be doing the bearings soon.
I added the guides shortly after buying it, and can't believe I have never had guides on a trailer before.
1956-1959 Tee Nee:
Needs a paint job but serves its purpose as is
1979 Monark 1440, 1980 Evinrude 25Hp Motor
Here are the before pics. It's an aluminum slide on that I snagged on CL for $600
When I removed the wood bunks, I discovered some severe pitting underneath.
nother shot
After dissassembly and sandblasting, this is where I am.
I mixed up some epoxy and started filling those pits. The left corner is gone here.
After everything sets up, Ill go over it with a belt sander.
More pitting
nother shot
More pitting
20' Lowe Olympic Jon Boat AlumaZilla
https://www.tinboats.net/forum/viewtopi ... 21&t=20643
HB 1197C
HB 1197C
Picked the boat up from a retired Gentlemen. It was grungy and highly oxidized and was sitting on the ground chained to a tree in his front yard with a "For Sale " sign on it.. I was going to get it if the price was right,so I had pulled the jon boat trailer up there. After agreeing to a price, He said, "well come on down here, the trailer for it is in the woods".
It was so over grown with weeds and honey suckle that I literally had to pull it out with the jeep. I really didn't want it but I thought I could get some money for the scrap metal. Turned out that other than surface rust,it wasn't in that bad of shape. The bearings, spindles, leaf springs and axle were great shape. So its been a work in progress since
. Fitting the side rails....
Welded up and a drain hole in the bottom. Need to find some caps for the tops.
12ft ryancraft w/ 8 hp Frankenstein rude
14 ft fisher w/ 15 hp rude
16 ft lowe w/ 25 hp Frankenstein rude
9.9 Rude / sleeper
6 hp Evinrude Sail Master
9.9 Rude / sleeper
