River Fishers - I Need Your Opinion
Frank R
South Eastern Michigan
I am outfitting my 14 foot Tracker Tadpole for river fishing. I took it out for the first time this season last week and it seemed like it needed trim tabs because the bow was too high as I accelerated.
Now I know most trim tabs are much smaller but I came across this picture while searching and I had an idea: what if I used a similar trim tab but modified the rods so the big tab can be moved to a 45 degree upright position. That way, after motoring upriver with the trim tab down, I could reach back and raise it up and then it would be useful for deflecting submerged tree branches. Like the way a drift boat has forward rocker. It could prevent a sudden stop on an otherwise immovable object.
try using the trim on your motor and tuck it " closest position to the transom" .... shift your load around .... but remember when you accelerate your boat the bow will rise, once you're planing it will flatten out and this is what you're after.
You might need transom wedges to get the motor tucked in further but the fins that you put on the motor itself would probably be a better solution to help keep the nose down. I don't think you want a full width trim plate on the back of your boat. Those are usually used with race boats like the one you pictured.
I have the motor in this position.
The problem is that I cannot go fast enough in the river to plane out. It would be too dangerous if I hit something submerged. So I throttle down and have tried standing using a tiller extension. This helps two ways: it puts my load in the middle of the boat and it has me standing up where I can get a better view ahead.
I am thinking of building a console because I am not thrilled with the tiller extension.
I had not considered this. A quick search has shown conflicting opinions on their usefulness. I will have to read more.
I am reluctant to use a fin because of the possibility of breakage to my engine.
i run a river that is full of logs and stumps .. i see your point totally ... i guess its a roll of the dice, i usually run at the point it will just stay on plane. i bump over stuff all the time but your going slow and the bumps/hits aren't hard, i've jumped plenty of logs and never busted a lower end. but i've seen goofballs hit stuff wide open and bounce the motor off the boat, no saftey cable LOL.
If you are close to planing out, just goose it for a few seconds to bring the bow down and then cut back on the throttle. The boat should stay on plane.
Using a big trim tab mounted to the boat itself would help keep the bow down, but it would also create a ton of drag .... you'd feel like you are dragging a drift sock behind you.
The fins are plastic so if they hit something it would probably just snap the fin. But if the fin is going to hit something, so is the lower end and you're in trouble at that point. I had a 90 hp Mercury on a 17' Wahoo and it had the fins and ran fine. I removed the fins and the boat would porpoise at anything past half throttle so I had to put them back on. The fins or wedges are probably your least expensive starting point.
I added the transom wedges to my jet and it made a difference in the bow position and porpoising so they do work in some situations, you would need to try them out to see if they work for your setup.
I'm with the others.
Move weight around, make sure motor is in the lowest position, and maybe a dole fin. If you hit that fin, you will already have hit with the lower unit.
I read somewhere that a guy was taking off his outboard, lost control of it, and the fin contacted the ground or boat, and broke the aluminum fin on the motor.
Not sure of the brand but there is a motor fin on the market that doesn't screw into the motor. It snaps on like a sandwich so you don't have to drill the cavitation plate. If you hit something with that it would probably unsnap as opposed to putting all the torque on your motor.
That sounds like it's talking about the skeg (the bottom portion of the motor) and yes, hitting that on something will break it off. The fins we are referring to are hydrofoil fins that usually bolt to the cavitation plate and are made of plastic so they won't hurt anything.
Try shifting some of the weight around first. My friend uses cinder blocks in the front of his Jon when he is out by himself. Helps with bow position and rides smoother.
I also have a feeling that your motor is not big enough or possibly boat and motor for river situations. I had a small 11' with a 5hp and it would not plane out especially on the river. I saw a guy recently with a 12' semi V with a small outboard in the river near my home. He couldn't plane out unless he sat on the cooler in the middle of the boat with a PVC pipe tiller extension. Even then it was barley making it.
What kind of boat and how many HP is she rated for? What outboard do you have? Pics would help too.
Frank R said:
What do you use for a prop guard?
i don't use a guard .. i just set my motor so its unlocked and can come up when it contacts anything.
Have you thought about a stick steer. This way you could sit in front and high.
Tracker Tadpole 14'. Rated up to 15 HP. I have an 8 HP electric start Mercury on it. I am pleased with the speed.
I am trying to hold down the overall weight. I may be launching this at some canoe launches at area parks. Two people can do it, I have seen it. But no reason to carry extra weight if I do not need to.
That is what I did last year. But when the water was low, and I had a friend along, the prop contacted the bottom twice. Now the Merc did have a long shaft on it but I have since built a jack plate.
Yes I have. I think I would prefer a small console right behind the front seat. I could hinge it so that it would fold down for transportation.
It was definitely a hydrofoil he was referring to.
