delete
seems like someone fell asleep in the chemistry class
do it - experiment yourself !!!
fasten the negative to a piece of scrap aluminum,
or any other metal, and very quickly drag
the positive wire across it.
THEN - you will know the reaction first hand.
and notice I said "scrap metal" - not on your boat hull.
and, IMHO, a quick test will not harm your battery. (QUICK test).
I, for one, would like to know your results.
Make sure you have eye protection on too. please video this as well.
Johnny said:
I guess we should save the part about standing on
wet concrete barefoot and playing with wires for
another LESSON ???????
YEEESSSSSS ABSOLUTELY - please video your results !!!!
make sure that you use salt water to wet that concrete
How much taxpayer money is spent on public education only to have this question come up ](*,)
On a more useful note, that is why you are always recommended to have your fuses as close to the battery as possible.
When I was a teen (just started driving) I had my trolling motor battery in the back of my truck. Had to slam on the brakes and the battery slid up under my toolbox. Not a pretty sight. The terminals got wedged under the tool box and caught a roll of paper towels on fire.
Anyway, to answer your question, YES. If you connect a 10ft wire to positive and a 10ft wire to negative, then touch it to a piece of aluminum, its no different than touching the two tires together, or laying wrench across the terminals.
aw come on Perch - weren't you young at one time or another ?
did you always take the advice of others ?
a quick arc of the wires on metal will not blow up a battery.
some loss of feeling in the fingertips after the blisters heal, maybe.
but the battery won't blow up.
EXPERIENCE is the best teacher !!!
never mind.
If the wires are creating a short somewhere and there is no fuse to stop it they can get extremely hot. They can get hot enough to burn through flesh in a heartbeat. The wires will be acting as the fuse and it may take a lot of heat before they burn themselves out depending on the wire size. The larger the wire the hotter they will get before burning out. I have seen wires get so hot they char the whole length of the wire and turn the insulation to ash in an instant.
About 25 years ago a guy I work with had a battery in his 14 ft boat fall over (no battery box) and short out against his 6 gal metal fuel tank. Burnt a hole in it, gas spilled, ignited. Him and his buddy both jumped out of boat and started swimming, his buddy almost drowned. No fire extinguisher either. Both could have been dead, pretty lucky and foolish.
Moral of the story.... do not play with batteries, lead acid or lithium, both are very unforgiving.
Tim
While fishing one day, I hooked a decent bass and got excited, had to maneuver a bit and tossed my landing net towards the stern.
Landing net hoop happened to land perfectly against both battery terminals and the handle of the net was in my lap.
It got real hot, real quick and was not very pretty.
